FS: VF8 turbo $275, $295 shipped.
legacymax
Post by legacymax »
I have a VF8 turbo for sale. It is similar in size to the TD05 but an older bearing design. It has a little bit of shaft play, i don't have any measurement but it spins freely. I have polished the casting ridges out of the 90 degree inlet bend. I also switched the lines over from a VF11 turbo. I bought it from Matt Monson about a year ago for $300 and haven't installed it so that is what i would like to get from it. i have decided to go with a rotated mount and a straight inlet turbo. PM me if interested. i will be in Mexico for a week starting on friday so i probably won't be able to respond quickly, sorry.
Thanks for looking!
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
legacymax
Post by legacymax »
bump
obo
Imprezive
Post by Imprezive »
pm sent...
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
Matt Monson
Post by Matt Monson »
RS-RA turbo FTW...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
legacymax
Post by legacymax »
bump, new price $295 shipped, help support my new engine build! :D It is packaged and ready to ship. comes with vf11 and vf8 water lines.
-max
bmxkelowna
Post by bmxkelowna »
so this would bolt right on as far as flanges and oil/coolent lines?
stipro
Post by stipro »
bmxkelowna wrote:so this would bolt right on as far as flanges and oil/coolent lines?
Yes, it is a direct bolt on to your VF11.
legacymax
Post by legacymax »
Thanks stipro, yes it will bolt right up, i replaced all the lines that were different than the vf11(on the vf8) with vf11 lines. Plus, i am sending the original lines with it.
-Max
High PSI
Post by High PSI »
What about the turbo inlet and outlet? How does it compare to the VF11?
legacymax
Post by legacymax »
You can see in the picture above, it has the 90 degree inlet so you can use it with your stock preturbo intake plumbing. The compresser outlet is zero degrees or flat where as the vf11 is at 45 degrees. Personnal I think the vf8 has a better angle because it is can be mated easier to a wrx intercooler. A 45 degree is better for a saab 900(or similar) side entrance intercooler.
-Max
legacymax
Post by legacymax »
More bouce for the ounce.
legacymax
Post by legacymax »
bump
