So I put a new turbo on the legacy...
I finally got around to not being lazy anymore and decided to put some new goodies on the legacy. I started small with a TurboXS rotated mount adapter pipe with a t3 flange. Then I went ahead and set my old used gt30r onto the pipe and bolted it all up. Then came the fun part, I tried to close the hood. Disaster. I ended up having to chop the inner frame of my hood, then tried to close the hood again... still nothing. So i ended up having to put washers onto where the hood bolts on to space the hood up a little bit so I can close the hood. It's also kind fo cool because it looks kind of jdm drifter ish and stuff like that. SO, long story short the car has a big ass turbo with a rotated kit and custom down pipe. The car is faster at 15lbs on this turbo then it was on the 16g when it made 317lb/ft. Thinking about turning the boost up makes me all jittery and things like that. I'll post some good pics of the setup as soon as I get a chance. Unless of course Phil can upload that pic I sent him. I'm hoping to get it on the dyno early next week. I'll keep everyone updated. Oh yea, full spool before 4k on a 30r is AWESOME!
Small cellphone pic I recieved last night at 9pm...
Oh how much ass that car is going to kick. Might start with one named Anthony...
Remember, this is the guy who pulled a 1.62 60' in a first gen eclipse...
Thanks for the Pic phil, I couldn't get one uploaded.
So yea, update time. I took the car and last night after I put a full exhaust on it and started doing some tuning. I started at wastegate boost (.8bar) and got the air fuels straight. By the time I was at 15psi I was cracking the tires loose on the 1-2 shift, so I kept turning it up. As of right now, the peak boost reading on my Blitz Dual-SBC is 1.63bar. 11.4:1 afr, but the only problem is for some reason the coupler on my throttle body kept popping off. I guess some genius (hint hint PHIL) decided to cut the throttle body to fit a top mount at some point in its life. However, for the time that pipe stayed on at 24psi it was ridiculous to say the very least. I'm thinking I might go nuts and try 2bar... I haven't recorded any knock yet and the injectors are only at 73% IDC. So we'll see how it goes.
Lol, good lord. Throttle body will be an easy fix.
Cracking all 4 loose on what kind of 1-2 shift? Rev-limiter style, or lift-throttle-no-clutch?
Thanks again for posting the pics Phil. As you can see I still have a little bit of cleaning up to do in the engine bay as this install was done quite quickly. It is however functional and for now that's all i'm worried about. My next step in the process is getting a filter on the thing. I think I am going to wait until I get the hydra so I don't have to worry about a maf. So what do ya think guys? Big Enough?
umm so for starters. specs on the injectors and what your tuning it with? and for enders what hot side. i noticed that its not a gt series from garrett? which 30r as well 3076??? s cover?
-jason
The injectors... To be honest I just took a set of stock 92-94 na injectors and modded them. As for the hotside, it's a .63 a/r. Oh yea, and I found out it's not a 30R. It's a non ball bearing 50trim.
Update: I finally found the limit of my modded inj./ modded maf combo, 25.5psi. Time to find a new alternative!
Tuning with a TurboXS DTEC fuel computer.
Time and money? Edwin cares not about such trivial things. It's time and money well spent.
I think that has to be one of the funniest things I have ever heard in response to that question.BAC5.2 wrote:Time and money? Edwin cares not about such trivial things. It's time and money well spent.
TurboXS rotated Kit (Up-pipe/downpipe/wastegate) - 1000
Exhaust - Ghetto crushbent with greddy muffler - 400
Dtec - 300 or so
Electronic boost controller - 500 (I had it laying around from my old car though)
FMIC - 1000 (but it was on the car when i bought it from phil)
Injectors/fuel rails - $25 (I modifyed them myself)
Fuel pump - 100 (again, on the car already)
Tranny - 5000
Turbo - Used 50 trim... 500
The look on STI and EVO owners face when I fly by them - Priceless
Dtec - 300 or so
Tranny - 5000
wow you got a nice set up there.
so i read that your still using the stock 22t heads correact?
dose your car still pull really hard up top, after 5k?
and where in the hell did you get that rotated turbo kit from i cant find one. and what modal car was it for?
thank you. and a job very well done there sir.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
It's the TurboXS prototype kit. He's one of the very few people in the world to have one (and the only one in the world with a car that has been tuned and is daily driven).
TurboXS will be releasing their External Wastegate Uppipe very soon, and the rotated mount adapter as well. Plus, they have a downpipe for that rotated setup that will be a sung, but workable fit for the Legacy.
oh wow, lucky guy.
thanks for explaining it to me BAC5.2.
i think i might just stick with the turbo heads for the torque!
Andy
94 L n/a 5spd, Rip
94 L n/a 5spd, Rip
