Turbo to Tmic intake
I am looking for suggestions that anyone has used for Ic tubing. The inlet on my Tmic is 1 3/4 in. What is in the diameter of the turbo outlet?
A wrx TMIC outlet to the throttle body is 2.75" ID not 3". And what turbo are you using? The VF-11 outlet is smaller than a TD04 or TD05. You can see info and pictures on my setup here
A 1 7/8" ID 90 deg deg hose is the best fit i found between the turbo outlet and the IC Y-pipe. If your running a VF11 size you need something around 1.5" ID
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
91 SS AT
