Moderators: Helpinators , Moderators
Splinter
Posts: 3058 Joined: Tue Aug 02, 2005 11:12 pm
Post
by Splinter » Fri Feb 16, 2007 5:26 am
Trying to track down a JDM bumper with the foglight brackets
Anyone have any clues on this?
Posts: 3335 Joined: Wed Feb 16, 2005 9:40 pm
Post
by 555BCTurbo » Fri Feb 16, 2007 5:43 am
Ebay...specifically a seller jhot-imports
the foglight brackets just screw in though, so all you really need are the brackets...
The Postface bumper skins are all the same
Splinter
Post
by Splinter » Fri Feb 16, 2007 5:56 am
I dont see how... the bumper hits the lamps when I try to put them in?
Post
by 555BCTurbo » Fri Feb 16, 2007 6:25 am
I have seen a number of postface cars with the fogs installed in the factory bumper, with no problems...
What exactly doesn't work?
Splinter
Post
by Splinter » Fri Feb 16, 2007 6:39 am
Maybe canadian spec bumpers are bigger..
Basically the top of the foglight mount would have to be 'inside' the bottom of the bumper in order for the lens to sit properly in the hole
Post
by 555BCTurbo » Fri Feb 16, 2007 6:59 am
So you are referring to the bumper beam and not the skin then?
If that is the case, just plasma cut some pieces out of the beam
Splinter
Post
by Splinter » Fri Feb 16, 2007 7:03 am
Yea, the beam
The JDM bumper looks similar enough to the Canadian one to pass inspection, a Canadian one with big scorched holes in it will not.
Post
by 555BCTurbo » Fri Feb 16, 2007 7:05 am
Yeah...the JDM beam is indeed different...
But you really can't see the beam unless you pull the bumper off...which I doubt they do in inspection?
Or are they that crazy
Splinter
Post
by Splinter » Fri Feb 16, 2007 7:26 am
They're really cracking down on stuff here....
But I suppose if I do get an inspection and fail I can always switch it back to stock...
dwreck30
Posts: 371 Joined: Wed May 05, 2004 5:32 am
Post
by dwreck30 » Fri Feb 16, 2007 7:54 am
Not sure, but I think some just flatten the JDM brackets. I got a set off a member here and mine are flattened.
- Derek
'06 STi
HomeSlice
Posts: 836 Joined: Wed Oct 16, 2002 4:47 am
Post
by HomeSlice » Thu Mar 01, 2007 2:35 pm
the jdm and edm bumper beam is totaly different then the usdm and can. ours looks like a big i beam-- jdm/edm is like sheet metal. i did the swap. you either get one from over the pond or cut your bumper beam to get the fogs in.
j-hot is a good idea--or find a good subaru salvage overseas.
MY93BC Legacy Sonora Sand---> black plasti-dip?
MY93GC Impreza Amethyst--> Glacier/aspen/pd White
93BC"edm" 93GC 90BC R.I.P.
New92
Posts: 573 Joined: Wed Mar 01, 2006 5:41 pm
Post
by New92 » Fri Mar 02, 2007 4:36 am
+1
1992 SS 5MT
She's growing faster in her old age!
