Head gasgets replacement
bny82
Post by bny82 »
Heya guys I have a question to ask.
I bought a 1990 liberty with EJ22 n/a for my dad all it needs is cvs and rear shocks and ......... Head gaskets!
I am feeling very lazy, has anyone successfully replaced the head gaskets without removing the rocker covers and rocker gear?
If I have to remove it all I will if I don't I won't hehe.
2006 2.0R Manual Sedan
Just to clarify.....are you talking about the valve covers & cam gear?
If so.....you could probably leave the valve covers on......and I don't think you'd have to remove the cam gear, but the timing belt obviously has to be removed.
bny82
Post by bny82 »
Yeah I am talking valve covers and cam gear. Over here is Aus they are also referred to as rocker assembly, just to confuse.
All the seals and valve cover gaskets are new I didn't want to waste money.
I'll give it a shot, if they get in the way have to come off so be it.
gto7419
Post by gto7419 »
You dont have to remove the valve covers or cam gears.
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
