38mm offset will it work?
Radial GT1
Post by Radial GT1 »
So I am springing for new rims, they are for a 2002 wrx. Will the offset fit on my 93 SS?
16X7 5-100/114 38SM
00 Camry; No wrenchin', just drive. Thank you Japan!
93 Legacy SS 4Eat 96K; All the wrenching I could ask for.
[quote="un-named"]What a man & a woman, and another man with a sheep & a midget want to do is their own business...[/quote]
That's pretty shallow.....If I had to guess....I'd say you'll rub on the rear fender lip....
Radial GT1
thanks
Radial GT1
I am looking at this aftermarket rims website. discoun tire and all their rims have a crazy offset. The highest i found was a 42mm offset. I read in a search that a 48 is perfect? Where are those rims at?
jamal
Vendor
Vendor
Post by jamal »
contact luke@tirerack on nasioc and he can get you other wheels that fit. Also subydude.com sells rotas, which are available in Subaru sizes. Or get a set of used subaru wheels. 06 WRX, 04 STi, and 05+ LGT 17" wheels all fit and look pretty good.
Radial GT1
roger that
SP-Boxer
Post by SP-Boxer »
Offset 53 is the only perfect size!!!
48-55 will do. Don't go lower or higher, it drives like hell :evil:
"I feel Legacy"
Post by entirelyturbo »
And will destroy your wheel bearings.
*Formerly DerFahrer*
jamal
Vendor
Vendor
Post by jamal »
The right offset also depends on wheel width. A wider wheel needs less positive offset to place the center of the wheel in line with the center of the bearing.
From nasioc:
Width .... Offset
6.5" ....... +53 to +55
7.0" ....... +50 to +53
7.5" ....... +47 to +50
8.0" ....... +43 to +47
SP-Boxer
Post by SP-Boxer »
jamal wrote:The right offset also depends on wheel width. A wider wheel needs less positive offset to place the center of the wheel in line with the center of the bearing.
From nasioc:
Width .... Offset
:? This is NOT true.
A 7" wheel is on both sides 0.5" wider than a 6" wheel!
Someone posted this list on a dutch Subaruclub site, and this really is not true.
The OEM STI MY01-MY04 wheels are 53, with a 7,5" wheel. :!: :wink:
"I feel Legacy"
Radial GT1
I ended up with an 50mm offset set of rims. ^this is great information!! I hope other people searching will find this because i searched for quite some time for this kind of information on rim offsets. Thanks again guys!
caveman
Post by caveman »
not to hijack the post but would the 38mm wheels work on a 90 awd wagon?
1990 Legacy Wagon. 2.2. 137k
know1
Post by know1 »
Just thought I would bump this back to life with a question. I am thinking about getting some new rims, the ones I was looking at were:
17X7 5X100/114.3 +42 with
215/40R17 tires
From what I've read these should fit without rubbing, just wanting to double check before comiting.
Splinter
Post by Splinter »
SP-Boxer wrote: :? This is NOT true.
THAT is not true.
It depends on the wheel.
I know for a fact because I can buy tubbed out wheels for my TA that go way further outward than inward so they dont hit suspension components
