Hey guys... there is a ton of information out there on this an Im aware of that Ive read alot. from my understanding I need all of the linkage... a.k.a. 3 bushings, 2 like arm things, a lever, a cup to hold the lever, and an adapter from the wrx to mate the Wrx linkage to the Legacy tranny. the reason I am doing this is because id like a shorter throw thats not so sloppy/shove it into gear/ grinding 2nd 24/7 when shifting fast... please correct me if im wrong on what I need
Upon doing this I also plan on buying all new kartboy bushings and a short throw level for the WRX... should with cure my problems... thanks guys...
I guess my friend has one from a 5MT WRX.... ( is this what I need)
Short Throw
A short shifter is only going to make the grinding 2nd worse.
Yes, the 5MT shift assembly from the WRX will work.
