intercooler clamps
Front, Top, Air, Water.
92ss satinsvoice
intercooler clamps
Post by 92ss satinsvoice »
hay yall im thinking on doing my front mount pretty soon and was wondering what kind of clamps i should use.
the phillps worm screw type. you think they will hold boost without coming un done? or the more expesnsive t-bolt type?
im just thinking ahead.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Post by 555BCTurbo »
T-bolts are best...but they are spendy...and the standard hose clamps should work fine for the amount of boost you will be putting through it
Post by BAC5.2 »
How much boost are you running?
Some people don't have a problem with standard worm-type. Some do. I'd use worm-type clamps.
Are your intercooler pipes bead rolled?
thehookeup
Post by thehookeup »
spend some money and get the t bolts. if you look hard enough online and ebay you can find good deals on them. if you dont got the dough, you better have something for the worm gear clamps to butt up against.
You can always drill 3 or 4 holes at the end of each pipe and then put in tiny screws. its a good cheep alternative to having the pipes rolled or beads welded on.
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Imprezive
Post by Imprezive »
T-Bolts for sure. Check out atpturbo.com. They accept paypal which is cool.
If you are clamping around high heat, such as the compressor outlet I'd recommend a spring loaded t-bolt clamp like the ones here http://turbohoses.com/Clamp.htm.
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
biggreen96
Post by biggreen96 »
well just last night I blew my system apart in the passenger fender @ 16 psi. I think I'm going to go get some t-bolt clamps. The worm screw type is easy to strip getting them tight.
Post by BAC5.2 »
Plus, worm clamps cut silicone hoses.
92ss satinsvoice
well right now im only running 6psi. but once i install my boost controller. front mount and fuel cut defender. im setin it at 15psi.
Andy
94 L n/a 5spd, Rip
thehookeup
are your pipes beaded or not?
has anyone used the hair spray method in addition to?
Andrew
Threshld1
Post by Threshld1 »
www.mcmaster.com search t-bolt clamp
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
92ss satinsvoice
my pipes are mandral bent. not crush. there 2.25 or 2.5 inch. cant remeber.
Andy
94 L n/a 5spd, Rip
New92
Post by New92 »
www.siliconeintakes.com
Super fast delivery and the best prices ive found so far.
Ben
1992 SS 5MT
She's growing faster in her old age!
Using decent T-bolts with non-beadrolled edges, I didn't blow a coupler untill a boost overrun to 24psi. I'm gonna bead roll the pipes, but I gotta get roun-tuit.
If your pipes don't fit together the best, or are trying to bend the coupler in a funny way, you're more apt to popping them. You want as little stress on them when you clamp them down. I have one that is pretty jacked, but hasn't gone anywhere do to the rolled edges.
