nasty squeel from brakes
just recently a nasty squeel/screech started commin from the rear brakes so i decided to replace the pads and rotors because they looked pretty bad well after all of that work i ended up with a mushy brake pedal (i think i know why this might be, i didnt bleed the system correctly) and the same squeel/screech i started with. the noise goes away once the brakes warm up (about 1/2-1 mile it did the same before the brake job) what could this be?
What kinda pads did you get?
Alot of times, the cheap parts store brand will just be a very noisy pad. We often have cars come back to the shop when the manager cheaps out on pads.
Rio Red '91 Legacy SS
