I bought 2 of the banjo fittings (AN-3 to 10mm), assuming that they didn't change from '91 to '92. I was wrong, and only needed one and had to scramble to order the proper fitting for the slave cylinder (AN-3 to m10x1.0). The correct fitting came in packs of 2, though, so I have an extra one of those as well.
I'll part with them for $15. All you need other than these is an AN-3 hose. I used a 14" hose with a straight swivel and a 90 degree end, though the same ends on a 12" hose would have been sufficient. I put the 90 degree end on the slave cylinder and the straight end on the master cylinder.
Here's a link to the site where I ordered my hose and one of the fittings from.
http://www.pegasusautoracing.com/produc ... ?Product=3
For clarification, these are for use if your slave cylinder has a fitting that looks like this:
I have no real use for these, so I figured I would offer them up for anyone else that may need them.
