Prefered MAF cleaner?
JTSPEED
Post by JTSPEED »
I hear there is a real spray for cleaning mafs but never seen it. Ive heard brake cleaner ,carb cleaner, and contact cleaner. What does everyone prefer?
throttle body cleaner :D
IronMonkeyL255
Post by IronMonkeyL255 »
They make a cleaner specifically for the MAF sensor.
Some carb cleaners will leave a residue on the MAF element, so I would avoid those. Brake cleaner has a tendency to work well.
Rio Red '91 Legacy SS
IronMonkeyL255 wrote:They make a cleaner specifically for the MAF sensor.
think throttle body cleaner has the same effect?
IronMonkeyL255
I dunno. Haven't tried it. If you have some, just spray it on a non-permeable surface and watch it dry. If there's stuff left on there afterwards, then I wouldn't use it.
Some carb cleaners don't leave a residue, but it's kinda hit-n-miss.
NuclearBacon
Post by NuclearBacon »
There is a spray cleaner for electrical components.... smells like carb cleaner, but it isnt. drys completly clean, and it worked on not one, but TWO MAF s!!!!!!
i highly reccommend it
its literally called Electrical component cleaner or something
-Luigi-
....Yes like nintendo
1987 GL10 Sedan 3.700 LSD
1988 XT6 FT4WD 3.900 Diff Lock
1992 EJ22T Touring Wagon 5MT Swap 4.111
Yeah....most throttle body cleaners leave a residue.
Post by entirelyturbo »
Yeah, if I clean a MAF sensor... which I honestly don't find necessary and really don't recommend... I use brake cleaner, because it evaporates completely.
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Matt Monson
Post by Matt Monson »
In my experience the only reason the MAF would get dirty would be
1. Too much oil on a K&N/Amsoil filter
2. Failure to use a proper filter.
If neither of these is the case, it's likely not going to help to "clean" the MAF...
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
now that there is probably residue on it, can i use brake cleaner now to clean it off?
