06 STI IC???
06 STI IC???
I know people have been having great success with the 06 wrx IC, what about the 06 STI IC, i find more of them for sale than the WRX!
I think that would run into the same issues as the earlier STI intercoolers. They are simply too thick to fit.
The '06 WRX units are actually smaller than the '02-'05 units, hence why they fit better. The '06 STI units are the same as they have been '04-'05.
Rio Red '91 Legacy SS
The forester i/c has a weird non slanted outlet for the bov.... Other than that, the forester tmic is EXACTLY the same as the 06 wrx tmic.
The wrx tmic is probably a little better because the angle for the bov plate makes it a little easier to clear the throttle linkage....
500cc Shifterkart, 125cc Shifterkart, 01 MX5, 93 Legacy Wagon (DIY Turbo)
Unless you block off the BPV plate, then it makes no difference.gto7419 wrote:The forester i/c has a weird non slanted outlet for the bov.... Other than that, the forester tmic is EXACTLY the same as the 06 wrx tmic.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
05 GD-STI
00- GF
Yeah, I made a plate and welded a tube to it so I could plumb the bov in a different spot....
Dscooby is correct - you have to either do what I did or run the bov off of somewhere else on the charge line.
So just as an fyi, I highly doubt anyone is going to get a stock wrx bov to fit in the stock location - the throttle cables interfere I believe....
