for my 91 SS what would i need for a TD05?
Red91SSFWD
Post by Red91SSFWD »
Buying a TD05 turbo and intercooler for my 91 SS. Wondering what i would need to get this thing on there? injectors etc. .
92ss satinsvoice
Post by 92ss satinsvoice »
um, you can get the turbo from deadbolt, or look for a used jdm one on ebay. some times people sell them on this site. make sure its has the 90 angle inlet or you'll have to do some fab work.
the turbo will bolt right in. as for injectors, you can use your stock ones but they will be maxed out really easy with this turbo, probley around, 13,14 psi but im not really sure. so dont hold that one on me.
if you want more then 12psi, you'll need a fuel cut defender. i would start looking for some fuel management and engine management after that point.also get a good, quality boost gauge and boost controller.
what kind of intercooler are you going to use? top mount or front?
Last edited by 92ss satinsvoice on Mon Jun 25, 2007 12:05 am, edited 1 time in total.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
Adam West
Post by Adam West »
Lots of stuff - FCD, Fuel pump, ypipe, intercooler, downpipe,...
What have I forgotten...MBC...???
Red91SSFWD
Im gonna be running the top mount setup.
dscoobydoo
Post by dscoobydoo »
To start with, you will need:
Walbro fuel pump,
larger ( 3 inch) exhaust and a good downpipe)
That will be just for running stock boost.
For more than stock boost you will need:
FCD, Boost controller,
at about 12 lbs you will max out the stock injectors.
From there you will need larger injectors and some EM to control them.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
You are actually maxing out the MAF sensor.....which causes the injectors to go to 100% IDC.
At some point you will start to lean but in the 12-14 psi range....you just don't have any control (this is assuming you have a good fuel pump)
So in reality to make things work properly, you need a higher range MAF sensor.
Adam West
Post by Adam West »
Not to hijack the thread but would one of these be useful in the situation you describe?
http://www.powercardtuning.com/
I just subscribed to Grassroots Motorsports and they say these are great, cheap way to control fuel. Anyone here used them? They are big in the Miata world...
Adam West
Post by Adam West »
You'd need the "Pro"
http://www.powercardtuning.com/products ... index.aspx
Also, $100 buck rebate...
http://www.powercardtuning.com/products/promo101.aspx
***edit: I don't work for these folks - ha, ha!
But I'm really curious about these...
dscoobydoo
Legacy777 wrote:You are actually maxing out the MAF sensor.....which causes the injectors to go to 100% IDC.
Actually, I am running a TD05 16G on the stock MAF with no issues. When I had it tuned, they said it was not maxing out at the 18lbs boost I am running.
05 GD-STI
00- GF
92ss satinsvoice
dscoobydoo wrote:Actually, I am running a TD05 16G on the stock MAF with no issues. When I had it tuned, they said it was not maxing out at the 18lbs boost I am running.
is your car pinging at all? what injectors are you running?
Andy
94 L n/a 5spd, Rip
Post by 555BCTurbo »
I run 21 psi on stock injectors, with consistent 11.5:1 AFRs
I have a piggyback though...
From my experiences with boost experimentation, you can safely do 14-15 psi on a VF8/VF12/TD05...after that the MAF rails, and the AFRs go immediately to around 15:1 on boost...which is very bad
Adam West
Post by Adam West »
DS isn't running stock injectors - yellow tops?
92ss satinsvoice
555BCTurbo wrote:I run 21 psi on stock injectors, with consistent 11.5:1 AFRs
damn, well that gives me a little hope when i start my build. you said your using a ralli-tek perfect power right?
Andy
94 L n/a 5spd, Rip
