I picked up a 90 Legacy LS Special (so th etitle says)
And th eTach, and fuel gauge don't work...
Just wondering if anyone eles has had this trouble, and knows a fix for it....I figure it's electrical since both the tach, and the fuel gauge aren't working (the low fuel light doesn't work either )
Any help would be appreciated....
Instrument trouble
Instrument trouble
[b]Huck[/b]
03 Impreza RS 5-Speed
89 XT-6 AWD 5-Speed Pearly (EG33 Powered aka FrankenWedge)
99 Forester S 5
94 Impreza Coupe
92 SVX LS-Tour RWD 5-Speed
99 Forester S 5
94 Impreza Coupe
Anyone?
maybe the schem for the instrument cluster, and where it's sinals come from....
The Tach, doesn't move off "0"
and the Fuel gauge stays on "Full"......
[b]Huck[/b]
99 Forester S 5
94 Impreza Coupe
99 Forester S 5
94 Impreza Coupe
yea check the connections in the back, and then before you put everything back together, check to see if its working again... if not then a quick easy cheep check would be to go to as junkyard and pull a good looking cluster. and plug it in and see if that one works. the cluster board might just be fried in a sense
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
Thanks for the imput guys...
Wher can I download the FSM's....I found the parts for the motor, but not the section that covers the gauges....
Anyone have a good gauge cluster they'd ship me for cheap, as there aren't any in the local yards around here...(I live in a Subaru desert )
I;'d hate to spend much for them, as I don't know if it'd fix it....
I did pull the cluster last week, and all the connections seemed fine, no obvious burnt places on the back....everything looked good.
[b]Huck[/b]
99 Forester S 5
94 Impreza Coupe
99 Forester S 5
94 Impreza Coupe
