Power light blinks after starting...
terranaj98
Post by terranaj98 »
After reading over previous posts...
i had a couple questions!
1) it seems like it could be the VSS1 or 2?
2) how do you check the TCU?
3) what is needed to check the TCU?
4) how do you check codes on the ECU as well..?
5) my power light blinked a couple more times then usual. so this is why im asking.. if its normal or not?
90' Subaru Legacy LS Wagon - 214k
PCV Changed
ECU Resetted
Tailgate Makeover. Thx Homedepot :P
Manarius
Post by Manarius »
If it blinks a few more times than normal, that means it has a stored code.
Read this page: http://www.surrealmirage.com/subaru/engine.html
