washing engine bay
206er
washing engine bay
Post by 206er »
just wondering how you guys do it? Ive actually never done it. :roll:
a pressure washer sounds like the fastest but also the harshest way. I'd probably be ok as long as I pulled the battery and didnt aim it at hose connections and stuff right?
I just sprayed my entire engine bay with engine cleaner and power washed with anger. Because of this after cleaning my engine would spudder. Reason for that was water got to the spark plug holes, just blew them out with compressed air and it was perfect!
Splinter
Post by Splinter »
Take out your ignitor too... Im pretty sure washing my engine was responsible for the death of mine.
Manarius
Post by Manarius »
Power washing is okay as long as you stay away from the battery, alternator, and coil pack. Aim at the valve covers and around their seals and under the intake to clean off without hitting too many electronics.
Getting water in there isn't going to kill it. The electronic parts from the factory are sealed.
Arctic Assassian
Post by Arctic Assassian »
you have to remember these cars are 16 years old.
Kickin' it old-school.
Murphy
Post by Murphy »
i tried to wash mine a month back after i went mudding, i just thought while i was spraying mud off the bottom of the motor i should go ahead an get the oil and grease off everything
bad idea, i took an air compressor and sprayed the water out of the plug holes and all the other holes and crevices, but i geuss there was still plenty stuck somewhere cause it sputtered and missed for almost a week, i was pissed off to cause i was thinking the problems might be permenant
1990 Legacy LS, 4EAT
livestrong14
Post by livestrong14 »
Cover your coilpack and plugs with plastic bags, don't focus water anywhere near them, and you'll be fine. Ive cleaned mine at least 3 times this way. Runs like a champ.
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
Adam West
Post by Adam West »
Power washing = bad idea. Yes, sputtering etc. You've got to go in by hand with a can of engine cleaner. Kleinkid can attest that there are no short cuts. Yikes! AW
aspect
Post by aspect »
I've hit my engine with a pressure washer tons of times with no consideration for electronics, never had a problem.
dirt-covered 91 SS prorally
pat richard roll cage, DMS 50mm, stickers...
SOLD :(
99 impreza RS
ver. 7 sti swap, ver. 6 RA suspension, JDM bodywork, rotated GT28rs
Just to note....you don't want to use a steam type cleaner where the water gets too hot. The hot temps/steam can cause the rubber to get brittle and crack prematurely.
Arctic Assassian
I like zep 50, with a hose coming straight from my water heater. Works every time.
