What happens if you dump the clutch with a 550 torque plate?
douglas vincent
You lose first. Badly.
So the story is kinda funny.....
I roll up for my last run of the night. It would NOT have been the last run as I wanted the previous run to be my last run, but I missed 2nd and was shooting for the damn 12.999.
So I roll up to the lights, open my door and shake hands with the control guy and say "Thank alot! Have a great winter!" Then I roll up to the line, line up, rev up, drop the clutch and !!!!!!!!!!!!!!
I roll off the line barely, get it into 2nd and continue down the line. But obviously not fast. I make it to the end, turn off and look under the hood. Nothing obvious. Try the gears. Stuck, but I am able to mess with the shifter long enough to get the transmission into 2nd and roll out of PIR. I am damned if I am going to get towed! I get on the freeway, shift to fifth and cruise! The noise is weird, not a single vibration that you can feel, but a nasty loose rattle that is rhythimic to the rpm....
So I make it about 15 miles or so back to the shop and am finally able to try 1st.
NOPE. All it does is "CRRRRRRRRRRRRRR". Good thing I have an extra tranny or two! And alot of downtime... haha. Although it is getting to be a bitch pulling the motor because there is so much crap in the engine bay now. haha.
But the good news?
I drove home again, for the 4th time, when I have suffered catastrophic damage (three blown pistons, and now the tranny).
And the better news? The new motor, with 150 miles or so on it, did a best of 13.1 @ 105 mph at only 14 psi!
But the good news?
Manarius
So, is that the first transmission you've blown? Isn't that the tranny you've been beating on for a long time now?
douglas vincent
3 time, but same tranny case all three times.
1st time, I lost 2nd on a BAAAAAAD mishift from 1st to 2nd getting into traffic.
2nd time, I lost 3rd shifting out of 4th on the freeway.
3rd time, I lost 1st drag racing.
douglas vincent
The 2nd and 3rd time, yes.
But only the 3rd time was due to POWAH!!!!!
The 2nd breakage I suspect was due to a loose piece of tooth getting sucked up into the tranny....
douglas vincent
all i do is race this wagon, so the only milage this engine gets basic driving to and from the track for the most part.
