2005 Legacy question (audio)
1-3-2-4
I wonder if an Alpine aftermarket head unit will fit? if so anyone have any installs of an aftermarket unit?
dropdfocus
Yes, Metra Electronics has a kit for the '05-'07 Legacy & Outback (99-8901).
Here is an online link to it:
http://www.amazon.com/Metra-TurboKits-9 ... B000LU9QD6
You also as of '05, Subarus require an antenna adaptor: 40-SB10
Here is the OEM-to-aftermarket wiring harness you'd need: 70-8901
Jason
1-3-2-4
darn thats only if you don't have the automatic climate control system.dropdfocus wrote:Yes, Metra Electronics has a kit for the '05-'07 Legacy & Outback (99-8901).
But in the pdf they show the auto climate control in some pictures...
http://documents.victorytechnologies.co ... 9-8901.pdf
dropdfocus
Well, all radios (aftermarket or OEM) are built to the German based D.I.N. sizing (width & height). Although that is on the basis that they didn't have a radio created with a front face to fit their dash's design (example - Ford Taurus, Ford Escort ZX2, Mazda MP5, <--seeing a Ford trend here?).
Jason
dropdfocus
You may also want to check in with these guys on the matter too:
http://www.legacygt.com/ ('05 + Legacy forum)
Jason
1-3-2-4
yeah I signed up early this morning but I can't make a post stilldropdfocus wrote:You may also want to check in with these guys on the matter too:
1-3-2-4
I was just wondering is the whole radio and climate in one unit behind the dash or no? I would think not.. How hard would it be for someone just to make a molding and cut the two pieces so it's not just one large piece?dropdfocus wrote:Well, all radios (aftermarket or OEM) are built to the German based D.I.N. sizing (width & height). Although that is on the basis that they didn't have a radio created with a front face to fit their dash's design (example - Ford Taurus, Ford Escort ZX2, Mazda MP5, <--seeing a Ford trend here?).
dropdfocus
Depends really. Ford only did it with the ZX2 as all one unit, and the Taurus sorta was all one. The front was just a controller and the brain was in the trunk. So you would think it'd be designed as two pieces, but not always... I haven't gotten the opertunity to tear into an '05 + Legacy dash yet. My buddy Matt has one a few houses from me. I may have to look into this...
Jason
1-3-2-4
I would be disappointed as I brought a whole Alpine unit with an XM radio to hook to it.. and used it in the impreza and forester and now maybe not being able to use it nowdropdfocus wrote:Depends really. Ford only did it with the ZX2 as all one unit, and the Taurus sorta was all one. The front was just a controller and the brain was in the trunk. So you would think it'd be designed as two pieces, but not always... I haven't gotten the opertunity to tear into an '05 + Legacy dash yet. My buddy Matt has one a few houses from me. I may have to look into this...
