Does anyone know if a fuel injectors for a '94 legacy will work with a '90? 2 of mine are faulty and I found some on ebay for cheap: http://cgi.ebay.com/ebaymotors/FUEL-INJ ... enameZWD1V
Impart some wisdom unto me!
Fuel injectors
Not really. The fuel rails are different, and the injectors are slightly different as well.
You also need to make sure you get the same type of injectors. The 90 & 91 non-turbo MY's had different injectors between the AT & MT vehicles.
douglas vincent
Not really.
The ECU is (sort of) matched to the injectors. The car will run, but in my case, I experienced running excessively rich when using 92-94 injectors with a 90 AT ECU.
As I said....you can physically do it, but I wouldn't recommend it with my experience.
