Moderators: Helpinators , Moderators
asc_up
Posts: 2473 Joined: Sun Sep 10, 2006 9:15 am
Post
by asc_up » Fri Oct 26, 2007 2:14 am
yeah my cel came on today and it was a code 22 (knock sensor).
so i replaced the KS with a brand new one and cleared the ecu. i still have the code!!
anyone know what else could be throwing the code?
the engine definitely does not have a knock. i don't hear anything and it only has 101K miles on it.
your thoughts?
kleinkid
Posts: 1213 Joined: Fri Jan 24, 2003 3:39 am
Post
by kleinkid » Fri Oct 26, 2007 2:37 am
How tight did you tighten the bolt for the knock sensor? If you torque it too much, you will damage the knock sensor. I know, I did it. Also, is the wire leading up to it in good condition?
Imprezive
Posts: 1428 Joined: Wed Jun 22, 2005 4:07 am
Post
by Imprezive » Fri Oct 26, 2007 2:38 am
you might have slight rod knock...
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
asc_up
Post
by asc_up » Fri Oct 26, 2007 2:40 am
i tightened it to 15 tq/lbs. it seems pretty snug...
and i'm positive i don't have any rod knock. my old engine did. this one is soooooooo unbelievably quiet lol.
i haven't checked the wire. i suppose it could be damaged. can i just splice in a new wire or is it an insulated wire?
Posts: 2385 Joined: Tue Mar 13, 2007 12:56 am
Post
by beatersubi » Fri Oct 26, 2007 4:17 am
Check/clean your grounds.
I was getting that code and a code for the o2 sensor after installing a brand new knock sensor. Turned out to be the ground on the left rear of the intake mani was loose.
Originalcyn wrote: Apparently everyone hates Gabe.
EvilAsPie
Posts: 29 Joined: Sun Aug 05, 2007 3:51 am
Post
by EvilAsPie » Sat Oct 27, 2007 3:13 am
How did you clear the ECU? Just unhooking the battery will not always do it.
asc_up
Post
by asc_up » Wed Oct 31, 2007 9:09 pm
i've tried unplugging the battery and leaving it over night and i've tried doing the whole reset where you drive around with the connectors plugged in and whatnot.
i rewired the knocksensor.
now when my car is cold and i start it there isn't a CEL, but once it warms up that light pops back on.
any ideas?
maybe it's just a bad ecu?
but i did pull the ecu and it looked fine...
Posts: 27932 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Thu Nov 01, 2007 2:49 pm
What did you do with the knock sensor? How did you "rewire" it?
asc_up
Post
by asc_up » Thu Nov 01, 2007 9:34 pm
i took the signal wire and wired it straight to the ecu.
then i took the shield wire from the ecu straight to the chassis.
what gets me is that the light will be off when i first start the car and then after about 5-10 minutes it will come back on...
asc_up
Post
by asc_up » Fri Nov 02, 2007 6:48 am
bump
Post
by Legacy777 » Fri Nov 02, 2007 6:19 pm
So you just ran two new wires for the knock sensor?
How are your engine grounds?
asc_up
Post
by asc_up » Sun Nov 04, 2007 7:58 pm
oh wow. my wiring was fine apparently.
i ended up just taking it to a shop.
the person who owned the car before me put the wrong cam angle sensor on so it was causing something to do something which caused another something to do something and throw a knock sensor code.
lol i never would have figured that out.
Post
by beatersubi » Sun Nov 04, 2007 11:32 pm
That sounds fishy to me.
asc_up
Post
by asc_up » Mon Nov 05, 2007 12:13 am
kinda what i thought.
but they fixed it for free.
and it all works great now.
lol so i'm all good.
