Help!I got a lower boost and fault code 65
小山&
Post by 小山& »
HI :lol: I come from Hong Kong,i see here many profressional people in this web site , everbody can help me? :(
guestions: My car is 97 Legacy BG5 AT Twin Turbo,no any specail
problem ,but the turbo just boost at 0.5Bar and some
time got a fault code 65 (Vaccum pressure sensor) .
I got a bad idea ! Install boost contorller to solve the
problem ,but i push the throttle fully ,the boost will go
up and down three time ,max just get 0.8 Bar,if i push
1/3 throttle , will stability keep in 0.8 Bar . What
happen in this case (lower boost and fault code 65)?
Dynamic Entry
Post by Dynamic Entry »
Welcome to the board! :)
I do not know the answer to your question, sorry, but someone else may be able to help you.
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Arctic Assassian
Post by Arctic Assassian »
Seems like you may need a new MAP sensor.
Kickin' it old-school.
小山&
Post by 小山& »
Arctic Assassian wrote:Seems like you may need a new MAP sensor.
Today I repeat to see all the board find a semi problem like this,[/url]http://bbs.legacycentral.org/viewtopic.php?t=33291
[url]it maybbe KNOCK SENSOR crack ,I feel that like ECU going on to the (Safe Mode).I already change the VACCUM PRESSURE SENSOR but no efect ,PRESSURE SENSOR I tested no problem ,I want to test KNOCK SENSOR now.I asked other people said 65code means:
1 VACCUM PRESSURE SENSOR .2 1st turbne change 2nd turbine timing wrong .3th boost lowest
小山&
Post by 小山& »
Dynamic Entry wrote:Welcome to the board! :)
Thank You :D
小山&
Post by 小山& »
I changed KNOCK SENSOR but as same as undo ,no efect , have any suggest?
Hello and welcome.
I'm not sure if i fully understand your symptoms or problem. But have you checked all of your vacuum lines? I know there are many on a single turbo, and probably twice as many on a twin turbo.
小山&
Post by 小山& »
beatersubi wrote:Hello and welcome.
I checked all the vaccum line no wrong input,no vaccum leaks.If I can find the problem, I will report to everbody !Thank. :D
94legacy
Post by 94legacy »
sounds like the problem might be "in" the ECU. find a good ECU and plug it in and see if the problem gos away.
