STi & Turbo Legacy Up-pipes are identical
I did a little searching, and found a comment, but nothing definitive.
The two up-pipes are identical. I measured the ID of the piping at both the inlet & outlet. They're the same. I'll have to double check, but I'm pretty sure the ID is 1-5/8".
The only differences is that the STi up-pipe metal shielding has "Subaru" stamped in it. Other then that, they're identical.
stipro
Post by stipro »
My 91 ss has subaru stamped on it up-pipe and its stock, wierd!!
hmmm.....pretty sure the one I got from Frank doesn't. I'll have to double check.
Threshld1
Post by Threshld1 »
They are defiantly the same, im currently using a v.2 up-pipe which came on my 16g since the OEM heatshields were rattling like mad.
93 SS 5MT - TD05H-16G, 06 TMIC, Walbro, Zeitronix WB-02 - Scrapped too much rust
91 SS AT
97 Outback - Prodrive quick rack, DMS 40
Brat4by4
Stratified
Post by Brat4by4 »
They are the same. The heat shielding is welded on slightly differently.
In fact, the word is once the existing stock of Turbo Legacy up-pipes run out it will be superceded by the STi part number.
Trace
Post by Trace »
That means our up-pipe is just as good as the STi ones and an upgrade won't be necessary?
Post by 555BCTurbo »
Trace wrote:That means our up-pipe is just as good as the STi ones and an upgrade won't be necessary?
Ummm...yeah
dropdfocus
Post by dropdfocus »
Doh! :shock: And all of those loyal owners who purchased someone's STi take-off U/P because the STi owner went aftermarket essentially wasted what ever cash they paid for the stock STi pipe... Sad really. Glad I found out ahead of time before I made the same mistake. :mrgreen:
Jason
Trace
Post by Trace »
same here lol
bmxkelowna
Post by bmxkelowna »
was that comment from me?
i had my friends v7 sti uppipe and my 92 turbo legacy uppipe in each hand and they idenitcal
There is a benefit to the STi up-pipe.....it's not 10+ years old. The studs are less likely to be messed up, or stuck, not to mention rust, rattles, etc.
That was my main reasoning for going with the STi up-pipe....that and I got one locally.
