I was able to remove the forward bolts on the linkage assembly - but only because there was no longer ANY bushing material left in the part. Now that I've got the replacement bushings in place - I no longer have enough rotation in the linkage to re-insert the cross bolt.
I have decided that the "pin" attaching the 1st linkage to the tranny input shaft will have to come out & be replaced. I started poking (and pounding) around this pin, but was only able to remove a mysterious "inner" pin. The outer section of this pin won't budge a bit.
What's the trick to removing the pin?
Also, I seem to recall awhile back a thread with photos of someone documenting this bushing replacement process... but no amount of searching on my part has resulted in any successful links or photos. Any help there too?
