06' STi Wheels
livestrong14
06' STi Wheels
Post by livestrong14 »
Hey guys, I am looking at getting a set of 06 sti wheels. I believe the lug pattern is 5x114 is that true? Is there any way to swap hubs to make them work? How about SVX parts?
I am looking at getting them for $100 here in Idaho.
Thanks,
-Devan
91 SS -Carbon Bronze Pearl
EJ257/EJ205 Hybrid
93 Ford Ranger-DD
91 Rio Red SS- RallyX Project
93 AWD Sedan- FOR SALE!
jamal
Vendor
Vendor
Post by jamal »
not without spending $1000 at 6gunracing.com
actually no even then you need an R180 and axles.
DLC
Post by DLC »
I have heard about hub adapters, but haven't looked into them.
You'd also be running an 8" wide wheel on a BC. Gooooood luck with that.
Legacy Central
jamal
Vendor
Vendor
Post by jamal »
hub adapters are garbage and a VERY bad idea.
#1- gives an extra 15-20mm positive offset
#2- have to cut the existing studs to get them to fit
That should really be enough to convince you.
8" +53et wheels with 225s should clear ground control sleeves and rolled fenders. It puts the tire in the same place as my 7" wide wheels and I'm running 225s.
dscoobydoo
Post by dscoobydoo »
Sadly, NO.
But you can sell them to me for the $100 so I can use them on my 05 STI.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Post by 555BCTurbo »
Yeah, you will be into it way more than $100 lol
legacymax
Post by legacymax »
buy them for $100, sell them for $1000 on NASIOC, then go buy a set of 04 STi wheels which are 5X100.
-Max
95 impreza Rally car. 3.0 H6
88 Toyota fj62 OME lift.
scuzzy
Post by scuzzy »
8" wheels are a pain in the ass to fit, trust me; I spent about six hours over the course of two nights getting mine to BARELY clear the spring perches.
we're talking such small clearance that for the first 200 miles anything over 90mph made a high pitched rubbing noise as the tires expanded. now that the tread has a little new worn off of it they do better (no more rubbing) but it's not worth it unless you have coilovers.
and expect to roll your fenders a good deal to get them to clear, or you'll chew them up.
get 7.5" wheels, much less hassle.
#82 M4 TRSCCA Rallycross
Coy
Post by Coy »
so you cant swap the hubs to change the bolt pattern at all, unless you go rob a bank or something?
ive got some really nice universal 5 lug enki wheels that arent universal enough to fit a subie.
92 Legacy L Wagon AWD MTX
Dirty? Probably.
seriously, who the hell put the cup holder there???
I know someone who used STi rear knuckles with svx rotors and backing plates to use normal rear brakes on his Impreza coupe. You can make hybrid axles, but things add up very quickly.
Step one: Buy wheels for $100
Step two: Post on NASIOC
Step three: ????????
Step four: Profit
