Am I an idiot or what????
tahiti350
Post by tahiti350 »
Okay, I may be a semi-neb, but I just spent over 45 minutes with my head under the dash looking for the black and green connectors, and while there are lots of black ones I didn't see a single green connector under there.
I did see a black wire with a yellowish stripe that went thru a single connector. Disconnected it, and it didn't do anything obvious. I also disconnected the battery for around 15-20 minutes, and held the brake pedal down for 30 seconds, then pumped it 30 times, cycled the key a few times for good measure, then hooked the battery back up. the time on the clock reset, but I couldn't tell any difference in the way it ran afterwards....
Does anyone have a picture of these connectors so I can reset my computer. I don't have a CEL, but the idle is still around 1500 rpm.
Also, does anyone have the part # for the temp sender? Schucks (Skragen) only lists one temp sender, but don't specify gauge or computer. They do have one for the fan control though.
TheSubaruJunkie
Post by TheSubaruJunkie »
If you wanna reset your ECU, remove the negative terminal from your battery and leave it off overnight.
1983 Subaru GL-10 Brat
1986 Toyota 4Runner
Murphy
Post by Murphy »
doesnt it take about 30 minutes to reset it? thats what ive always done, but ive never had anyway of telling if it works though
does it idle 1500 all the time? even after youve driven around and warmed it up?
i need to get some new dash lights, my CEL and several others dont work
1990 Legacy LS, 4EAT
douglas vincent
Post by douglas vincent »
There are very likely HIGH odds that the damn green one is taped up into a roll of wiring. I had that happent to me!
legacy92ej22t
Post by legacy92ej22t »
Yeah, the green one can be a bitch to find.
The way you tell if the ecu reset is to see if your stored CEL codes (the small black connector test) went away or not.
The green connector is for a D-check. That's an active test to see current codes.
Josh (Legacy777) has a good right up on his site for these checks.
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
tahiti350
Post by tahiti350 »
Murphy wrote:doesnt it take about 30 minutes to reset it? thats what ive always done, but ive never had anyway of telling if it works though
Okay, I'll disconnect the negative today at work and see what it does.
Idle starts out okay when cold, but climbs as it warms up. After I get to work (about 15 miles) it's idling at 1500 with everything turned off.
The part number you want is here:
http://www.graphics.cornell.edu/~v/partnumbers.html
tahiti350
Post by tahiti350 »
Thanks for the part number link, that's cool
:-D
magicmike
Post by magicmike »
I just touch the ground connector to the posotive one after i have disconnected it from the battery. The whole time thing is to discharge the capactors which may hold some juice. Touching the two terminals together discharges the caps instantly.
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
tahiti350
Post by tahiti350 »
Legacy777,
thanks for the links to the info, extremely helpful...
tahiti350
Post by tahiti350 »
Okay, I changed the temp sensor and did the reset as shown in the link, and it's still the same. Hot idle is 1300-1500 rpm and sounds like it's lean, almost like a vacumn leak, but I can't find any bad hoses. Maybe a brake booster leaking? Brakes still feel good, but maybe it got damaged when the wife stabbed the brakes when she wrecked it?
Any other ideas? Do the tach's ever go bad? How would you hook up a different tach to check it?
Are there any codes stored, or show during the d-check mode?
Is this on the 90 legacy in your sig?
When did you first experience the high idle? Did something happen/change? Did you do anything with the throttle body?
Please provide any more details you can.
tahiti350
Post by tahiti350 »
Yes it's the '90 in the sig. Wife wrecked it back in July, I finally got it fixed and back on the road in September. Idle was fine for a while then started climbing slowly until it hit the 1300-1500 range, and seems to have stabilized there.
I haven't been able to find the green and black connectors yet, between work, weather, and other cars breaking I haven't had time to screw with it.
Throttle body hasn't been messed with by me, but the lower idle set screw is chewed up, so who knows. It ran fine for several years with a good idle, 800-900 in neutral, 650-750 in gear. Still runs strong, but only got 26 mpg hiway last trip, normally 28-29.
O2 sensor??
Nah.....O2 sensor shouldn't do that. You may want to check the TPS
http://main.experiencetherave.com/subar ... sting1.jpg
http://main.experiencetherave.com/subar ... sting2.jpg
http://main.experiencetherave.com/subar ... sting3.jpg
If everything's good with 1 & 2, check/set the TPS according to scan 3
tahiti350
Post by tahiti350 »
okay, thanks, need to borrow the neighbors digital VM for that. Hoping to spend a little tiome on it tomorrow, after I fix some wiring on my truckl soI have something to drive. I gave the Subie back to the wife (hopefully I don't have to find more fenders anytime soon....)
tahiti350
Post by tahiti350 »
Okay, more info:
Idle is still 1300-1500 rpm hot in neutral, sounds like it has a vacumn leak, but I've checked all the vacumn lines and they are good. If I disconnect the IAC the idle drops to around 800 rpm, but the front 2 cylinders quit firing. In this configuration if I bring the throttle up slightly the front 2 start firing again, and stop when I release it. It won't start cold without bumping the throttle up a little for the first couple of seconds.
So far I've:
swapped plugs front to back, replaced temp sensor, replaced PCV valve, inspected vacumn lines, reset the ECU twice, looked for the green and black connectors (still can't find them...), so I haven't pulled any codes, but I DON'T have a CEL. My neighbor has been gone all weekend (need to borrow his DVM), so I haven't been able to check the TPS either.
With this info can anyone point me in a direction? I know I need to check the TPS, and find the black/green connectors and see if anything is stored, but until I can get that done I'm at a loss.
I can help you find the connectors, if you wanna swing by some day. I also have a multimeter, but its not digital.
You could also try the guys at pacific import. They're very helpful, they don't overcharge, and they're close.
tonflo
Post by tonflo »
My green connectors were up high on the left where they were supposed to be. But the black ones were above & slightly to the left of the gas pedal, so you might want to check there.
'94 Legacy Touring wagon. Quicksilver metallic. WRX rims, Whiteline ALK, SS brakelines, GR2s, alum. coolant tank. Gone, but not forgotten
'99 NSX, Alex Zanardi edition, #11/50. All stock & red 2 go
'05 Corolla XRS
tahiti350
Post by tahiti350 »
Thanks Tonflo, I'll look again, if I still can't find them I'll get in touch with Beatersubi.
Beater, I may take you up on the offer, and thanks for the recommend on Pacific Imports I may just give them a call at this point.
Anyone think I could just be the O2 sensor? I changed it with used one when I got the car (wires were cut off the one in it). maybe it's failed and sending a dead rich signal so the computer is turning down fuel and cranking the IAC full open?
