What problems from wrong spark plug gap?
I may have made the gap on a set of spark plugs too close...what problems would that usually cause?
internetautomart
internetautomart
you will probably run richer because you have a smaller spark so incomplete combustion will happen as well.
"A small kernel will make the engine run as though the ignition timing was retarded, and a large one as though the timing was advanced."
the quote is from WIKI so take it for what it is.
94 BC w/ AWD Sold 6/25/08
92 BJ Rust bucket gone
90 BC (I think) Stripper, gone since 2k
86 GL10 Turbo 4wd, Gone since 99
It depends on the cylinder pressure. A higher pressure will benefit from a reduced gap.
OK. The higher the cylinder pressure, the harder it is to ionize the air for the spark to jump the gap. A longer distance can cause a delay in firing or a miss altogether.
With a $1 plug gapping tool. Some plugs come pre-gapped, but you should probably check them even so.
Most spark plugs are pregapped from the factory these days... Most of us like to use NGK BKR6E-11 plugs, right? The "11" means "1.1 millimeter gap."
So you generally don't need to adjust the gap at all.
- quasi-mod-o
Every BKR6E11 I've ever installed is gapped right around .043 from the factory.
I usually run a .040 gap, but I honestly would probably do better to run a bigger gap. I'm nonturbo and stock, so running a smaller gap doesn't do me much good. Maybe that has something to do with why my engine pings on 89 octane.
SemperGuard
sammydafish
The concept that high boost can blow out a spark is a farce, lets set that record straight. Plugs don't blow out, the ignition may lack the power to jump a spark across the dense air (an insulator) that is in the cylinder during scenarios with extremely high cylinder pressures. similar to what evolutionmovement's post says. Nothing in this situation is getting "blown out"206er wrote:benefit might be a strong word, a narrow gap will be harder to blow out.
a narrower gap will be easier on the coils.
- Junior
95L Wagon on T3/T4 boost :)
- quasi-mod-o
SemperGuard
I wont expect you to because it wont happen. If anything the insulator will crack.subyluvr2212 wrote:Don't expect me to retap the spark plug threads in your heads after you strip them out. Not without some money involved anyway.SemperGuard wrote:Gap? Just slam those bitches home with an impact right out of the box. Gapping is for suckers.
Anti-seize is for wimps.
Suckers and wimps I say!
- quasi-mod-o
Your spark plugs shouldn't be in the engine long enough for you to need anti-seize.
Mr. SemperGuard, you do understand our heads are aluminum right?
I'd be more than happy to demonstrate on your engine how easy it is to ruin aluminum threads
I like how you're calling people wimps, and then using an impact wrench to tighten spark plugs
I never use antiseize, just a little oil on the threads and I've never had them stick.
SemperGuard
Baby you should know me by now. If one of us ever ends up on each others coasts, I will gladly slam multiple spark plugs home with an impact for yousubyluvr2212 wrote:Your spark plugs shouldn't be in the engine long enough for you to need anti-seize.
We should end this before the thread gets closed.
- quasi-mod-o
If you guys are looking to push things a bit further (larger than stock turbos and more boost), I would definitely not run the NGK -11 plugs on turbo motors. That's far too much gap for boosted applications running decent sized turbos and a bit of boost. Sure, you can do it, but it'll put a lot of strain on your ignition system and compromise misfires as well.vrg3 wrote:Most spark plugs are pregapped from the factory these days... Most of us like to use NGK BKR6E-11 plugs, right? The "11" means "1.1 millimeter gap."
On decently modded Subarus, I typically run NGK BKR7EIX and even the 8's for cars making a bit more power. These plugs are gapped at .030" out of the box. If the Subaru layout wasn't so dificult to work on (well at least on Imprezas) I would try pushing the gaps out a little. But it works great like this and no worries. Plus, Iridium performs as well as copper and has the maintenance life span of platinum.
1.) '02 WRX-2482cc-TD06H-20G-FMIC (just sold)
2.) '90 Legacy-2.5 turbo, VF39, Haltech E8 in-hand - waiting for the 5mt swap
sammydafish
tmarcel wrote:If you guys are looking to push things a bit further (larger than stock turbos and more boost), I would definitely not run the NGK -11 plugs on turbo motors. That's far too much gap for boosted applications running decent sized turbos and a bit of boost. Sure, you can do it, but it'll put a lot of strain on your ignition system and compromise misfires as well.vrg3 wrote:Most spark plugs are pregapped from the factory these days... Most of us like to use NGK BKR6E-11 plugs, right? The "11" means "1.1 millimeter gap."
the 6 -7 -8 you refer to is plug temperature, not gap. It refers to the rate in which the plug can dissipate heat to the head. Unless you have a preignition problem and believe the plug is the hot spot, or you have a fouling problem, there is no reason to change the plug temperature from stock.
Hotter plugs resist fouling, but can become to hot and cause preignition.
- Junior
Thanks for letting me know this FACT about heat range and plugssammydafish wrote:
