Motor trouble
93TurboLegacy
Motor trouble
Post by 93TurboLegacy »
When I run the car hard for awhile and let off the gas and get back on it it just dies and when I let off the gas it starts back up. I have no clue what it could be.
EJ22T
Post by 555BCTurbo »
Do you have an aftermarket blowoff valve?
93TurboLegacy
nope. stock. nobody can figure it out.
EJ22T
Arctic Assassian
Post by Arctic Assassian »
auto or manual?
Kickin' it old-school.
Any other symptoms the engine/car may have?
93TurboLegacy
manual. and sometimes when you ease off the gas it sorta stutters and I lose all boost but when you push the gas back down its fine. Its does this pretty much all the time.
EJ22T
Sounds like a fueling or air flow issue. If you have a spare MAF, you could try swapping the current one out. Or you could try cleaning the current one.
Arctic Assassian
If you take your foot off the gas in neutral while moving, does it die? or just stutter?
You could just need a fuel filter and a fuel injection cleaner done. If I were you I would take it to the dealer to have a service done to it.
93TurboLegacy
No it doesnt cut off while in neutral or it never has on me.
EJ22T
