OOPS!!! I found the problem
Snow-Attack
Post by Snow-Attack »
so regarding to my previous post
http://bbs.legacycentral.org/viewtopic.php?t=34919
apparently the idler gear below and to the right of the crank shaft gear looking at the front of the engine didn't like sustained high rpm lol....my bad!!! and it seazed up and and sheared off the bolt,moved over like 3" directly under the crankshaft gear, took some aluminum off the block, gouged my crank gear, and broke the plastic cover over everything :smt021 ... i think thats it lol. Has anyone had this happen to them before????
Ben
1994 subaru legacy
MI winter package heated seats,mirrors,dark grey interior,5MT 202k,wrx 16" wheels
1992 Touring Wagon LE
td04 turbo,wrx tmic,tinted windows,sti pink struts,lowering springs,16" wheels,wrx brakes,remote start,keyless entry,alarm
asc_up
Post by asc_up »
Not to that severity, but it does happen. The best way to go about fixing your problem would be to replace everything. The idler pullies, the tension pulley AND the tensioner, plus a new belt. That's just my opinion.
I worked on a 91 turbo legacy where the gear seized & shredded the timing belt
http://www.main.experiencetherave.com/s ... ddedtbelt/
Does anyone reuse idler pullies? If they spin smooth are they ok, or is it just asking for trouble?
Yeah I've reused them. The main problem is the grease dries up over time. So if you spin them, and they feel a little dry you could try replacing them.....I read about someone using a syringe and injecting grease into the bearings, since they are sealed.
The idler gear is the main one you want to keep an eye on, because if it goes, it'll do a lot more damage and tear things up.
Saskatoon Subaru
Post by Saskatoon Subaru »
spin the pulley's and if there are any rough spot's, or if you spin it and it sounds like theres sand in it, replace them.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
Cool, that's what I figured but I was a little wary after seeing Josh's pictures.:shock:
Thanks guys.
Snow-Attack
Haha ya my gear seazed and then just sheared off and left the timing belt in tacked.... so my bro has a spare 2.2 that he's sending me all the parts off of so thank you guys for the info and i will have him check that stuff before he goes through all the work!!! btw do you think it was probably the revs that really did me in???
1994 subaru legacy
