HEEELLLLPPP cant remove torque converter
1991legacyturbo
Post by 1991legacyturbo »
Hello all, i am currently doing my auto to manual swap, and i cant, for the life of me, get the darn stupid bolts off of the flexplate/torque converter. this is slowing my whole swap.
i currently have the tranny out but uuuurrrrrgggg.
anyone have suggesttions on how to get it off.
also, where is the ecu located??
Auto trannys suck!
thanks
1991legacyturbo
please someone help me
PhyrraM
Post by PhyrraM »
What are you doing to try?
There should be a straight shot at them from the access hole.
1991legacyturbo
please tell me where this access hole is
thanks
i have looked around and the only place i can see is on the bottom of the engine but that is impossible to get a socket or wrench in
PhyrraM
Post by PhyrraM »
1991legacyturbo
thank you very much, is there any screws holding itin??
PhyrraM
Post by PhyrraM »
Once you gain access to the hole, slowly turn the crankshaft and look for bolt heads. Take out every one you see in that hole. Turn the crank again after each bolt is removed. There are 4 or 6 bolt to take out. Seeing as you have the transmission off, the torque convertor will probably drop when you take out the last one.
1991legacyturbo
sorry, i knew that, i meant does the acess window have screws?
thanks
Hocrest
Post by Hocrest »
No, It's just a rubber plug.
[size=75]-97 Legacy (ain't never gonna die)
-92 SVX (attention whore)
-86 Brat (more fun than the SVX)
-92 SVX Racer (lightest SVX)[/size]
BXSS
Post by BXSS »
+1 remove the rubber plug behind the intake manifold, then remove the 4 bolts that hold the T/C to the flexplate & everything should come apart.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
