The Resurrection
dscoobydoo
The Resurrection
Post by dscoobydoo »
We picked up Dwreck's legacy this weekend. ( he is in AK and does not have the time for it)
Since this is Subaru #4 we now own, we are not sure of the plans for it.
It is going to be a bit before it makes it here to Seattle ( have a few wiring issues as well as the licensing.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
skid542
Post by skid542 »
So very glad to see this go to a good home. Had I not picked up my parts car and used up my funds I would have been all over it.
Please keep us posted on it's progress. Further, if you end up needing a hand on any of the wiring, I'm over in CDA and would be willing to lend some help.
Lee
beanis05
Re: The Resurrection
Post by beanis05 »
Any updates on this car
dscoobydoo
I had forgotten about this.
Well, I sourced another JDM 16G turbo, an AWIC core, 440 injectors and a few other parts I had laying around.
I will just post the pics and let them speak for themselves.
The car does still need some paint on the hood to re-do the clear coat issue.
I loaned the car to Rob to use as his test mule in hacking the ECU code.
But I too am going to put a 20G ECU in it, soI have two STI-RA 20G ECUs on route from Japan as we speak.
The car does run well with the 16G andthe 440's.
05 GD-STI
00- GF
beanis05
Post by beanis05 »
Nice
Threadsurrection!!!!!
Nice! Is it fast?
What are you using for the heat exchanger?
beanis05
Post by beanis05 »
beanis05 wrote:Nice
asotwavb
Post by asotwavb »
Is that an EJ20G being run on a 22T Harness?
How much boost are you running on the 16G with 440cc injectors? Injector Duty cycle by any chance?
dscoobydoo
It is still the EJ22T, but will soon be running on an EJ20G ECU. Stock boost right now, but plan on 15 lbs with the STI-RA ECU
05 GD-STI
00- GF
asotwavb
Post by asotwavb »
Sweet, looks *similar* to my set up...EJ20G on a 22t harness, 440 injectors, and a WAIC
I've been really thinking about the 16G, does it perform well at stock levels?
beanis05 wrote:
beanis05 wrote:Nice
It didn't work because you had "disable bbcode" checked. I fixed it.
dscoobydoo
The 16G and the 440's work pretty well with the stock ecu. Other than a loss in fuel economy, I have not noticed anything else bad. It idles good and the pick-up is much better.
05 GD-STI
00- GF
dscoobydoo
And now- my 20G ecu that just arrived from Japan:
05 GD-STI
00- GF
