does anyone make a short throw shifter-1990 legacy 2.2
Post by SILINC3R »
i have seen them on ebay for 1993 imprezas but not sure if that would work.
Aerotech
Post by Aerotech »
Shifters are all the same for Legacy, Impreza and WRXs, but later cars have an extra u-joint. STI shifter will bolt right in, but you need that extra joint to hook it up...about $60 from Subaru. Any add-on short shift kit that just changes geometry should work, no problem.
Jerry
Arctic Assassian
Post by Arctic Assassian »
I had the understanding you need a full linkage from a newer car to run a short throw shifter. Our design is very different.
Kickin' it old-school.
Post by 555BCTurbo »
Arctic Assassian wrote:I had the understanding you need a full linkage from a newer car to run a short throw shifter. Our design is very different.
This is more true...
Many of the later units have a backwards U-joint setup...so if you drive out the roll pin on the transmission and change the U-joint...it should work well.
Post by SILINC3R »
so the one off of ebay for like 30 bucks will work. it is only the shifter. i did not know if they would work so i just took a hack saw to my shifter to shorten it.
SILINC3R wrote:so the one off of ebay for like 30 bucks will work. it is only the shifter. i did not know if they would work so i just took a hack saw to my shifter to shorten it.
You have to have the matching shifter linkage assembly. So you will need to swap that out as well if you get the ebay shifter.
ciper
Post by ciper »
I have a spare u joint if someone wants. Its a common upgrade to buy a new one when installing a better shifter (since they get some play with age)
Post by SILINC3R »
well i am not sure what i need but know i have trouble putting it into reverse and fifth gear
Post by SILINC3R »
well since i have trouble shifting into reverse and fifth gear is that a bushing or what. i would take a picture but do not know how to post
Email me the pictures.
Chances are the bushings are shot.
Post by SILINC3R »
i have to replace the right cv axle in the morning tom. so i will take pictures of the shifter.
