removing the rev limiter
jeffast
Post by jeffast »
i need a diagram of the ecu for an impreza/legacy, i am building a rally car and useing a mild build on a motor for a bit till the radical one gets done. i am running solid lifter heads, and a few other goodies. but any way i want to be able to rapp the motor out to 7500 rpm. any one know how to remove it?
92 SVX LSL tour- 5spd swap baby
92 turbo touring wagon now also 5-speed swapped
89 xt6 stock
[quote="danetrain"]Fuck wyoming[/quote]
PhyrraM
Post by PhyrraM »
To remove it from the stock ECU would involve a custom EPROM.
I'm not sure who can do that affordably.
A standalone is most likely your best bet considering your other mods.
def09
Post by def09 »
I was looking for this also for a friend racing his Legacy on a 3/8 circle track. Some MSD igition units have adjustable rev limiters but I cant get a answer on if it can over-ride the ECU's set limit.
PhyrraM
Post by PhyrraM »
No it can't. The ECU fires the coils directly, so when the ECU hits rev limit, there will be no signal to 'override'.
def09
Post by def09 »
Bummer...but thanks for the response phyrram.
mxpunk
Post by mxpunk »
find "storm" on nasioc/rs25, he can hack the ecu's and raise the rev limit to whatever you need rilly.
1996 Impreza Outback Sport 5 speed ej22
1997 Impreza Brighton 5 speed ej18t
More then likely, he can only do that on the OBD2 ECU's.
ciper
Post by ciper »
With the 02 WRX and all DBW cars its VERY EASY to change the rev limiter. In fact you can even add a custom rev limiter at say 4k RPM that automatically disengages once VSS1 has a signal for launch control!
b3lha
Post by b3lha »
Depends what ECU your car has. Some Legacies between 1992 and 1996 use the same JECS OBD1 ECU as the SVX. But I think it's only the non-turbo cars, not the Turbo versions. I have been doing some work on my SVX ECU and I know where the rev limit is stored and how to reprogram it. If you have the same ECU and are good with computers and electronics then drop me an email and I'll explain it to you.
jeffast
Post by jeffast »
Legacy777 wrote:More then likely, he can only do that on the OBD2 ECU's.
just to bump this, storm can raise the limit to 7,500. he charges like $50 plus shipping for you to send your ecu to him. then he mails it back with the higher limit. he has like a 1 week turn around time. you can contact him on nasioc
89 xt6 stock
