WTB: 90-94 ej22t engine, harness, ecu
larry64bug
Post by larry64bug »
So, i'm starting my project. 64 bug with a ej22t and i need the most important part, the powerplant. This seems like an awesome site and you guys definetly seem very helpful. My dad also has a subaru swap going. He has a sandrail he's putting an '05 wrx engine into. He has the whole donor car luckily and it seems to be a little difficult wiring wise being so new. I've emailed enginewiring.com and he said due to an extennsive anti theft device the harness will be a little more work to cut down. If anyone has any info on this that'd be helpful. Thanks.
'64 bug soon to have ej22t
'03 Yamaha R1 (for sale)
Freepistol
Post by Freepistol »
Hi Larry,
i don't have the engine for sale, but I have the intake, exhaust, turbo, ECU, and harness for sale from a '94 22t.
Ben
94legacy2.2
Post by 94legacy2.2 »
I also have a ecu forsale
let me know if you need it, it came from a 93 atx t-leg
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
ciper
Post by ciper »
For help with the 05 WRX swap search through this specific forum for a bit http://forums.nasioc.com/forums/forumdisplay.php?f=87
The 05 was the last year of the two liter engine and also the last NON IMMOBILIZER ECU!!! The engineharness guys are incorrect. If he truely has an 05 WRX engine it should be similar in difficulty to an 02 WRX swap. They did change the wire harness but if he gets the FSM for the MY of the engine he'll be just fine.
larry64bug
sORRY, COULD I GET THAT IN LAMENS TERMS? LOL. FSM AND MY? HE DOES HAVE THE WHOLE HARNESS AND CAR SO HE SHOULD BE GOO.
Blackbart
Vendor
Vendor
Post by Blackbart »
I have an ej22t that was in a vanagon, the owner removed it because he could not get it to run correctly, the problem was he was using an n/a ecu. I have the correct ecu for it.
Located in PA.
Send me a PM if interested.
