1993 Legacy part out
So you may have heard I lost a rod bearing or three in my Legacy so it's getting parted out. I'm keeping some of the good stuff though.
The body is not in good shape and I wouldn't recommend purchasing any of the body panels. Especially the hood and trunk, unless you're having them painted. Most of the interior and trim is in good shape, the passenger headlight and turn signal are damaged, the grill is cracked, and the front left wheel bearing is questionable
Things that I don't have for sale
rear swaybar
struts/springs
front bumper
wheels
original brakes
things that are in very good condition:
front pass wheel bearing/hub/upright
ball joints
tie rods
steering rack
automatic OEM radiator
knock sensor
JECS maf
things that are in bad condition:
short block
transmission
exterior
pass. headlight and turn signal
grille
additional things I have/will have for sale
2.5 gt 20mm front swaybar (fits all non-turbos)
2.5 gt brakes
2.5 gt black and grey front seats
2.5 gt suspension (struts are not blown)
04 sti springs and tops/perches
Wiring harness adapter to use modern Subaru radios. Soldered and heat shrunk using a David Carter harness so the dimmer and power antenna will work.
I'll add more things when I think of them. The car is located in Fountain Valley, CA 92708
my paypal address is peterleclaire (at) gmail (dot) com
rear swaybar
struts/springs
front bumper
wheels
original brakes
ball joints
tie rods
steering rack
knock sensor
JECS maf
short block
transmission
exterior
grille
2.5 gt brakes
$40. I got it used a month ago for that much.
oooh these seem to be a popular item in the parts shed. hows about $30 shipped
yeah I put them in about a year and a half ago and they were new OEM parts. They should still be in great condition, I'll take them out tomorrow or monday when I pull my front suspension off and let you know.ericem wrote:Jamal are the ball joints OEM and almost new? New OEM ones are $30 each.
no sorry it's an automatic.flystiguy wrote:Was it a 5-speed tranny? If so do you what kind? and do you have the clutch pedal set?
You know what I changed my mind. I prefer to go brand new, unless your willing to give a good price and make sure the seals are good!! I was also wondering if you ahve the nippon abs unit and if so i need the two relays from it.jamal wrote:yeah I put them in about a year and a half ago and they were new OEM parts. They should still be in great condition, I'll take them out tomorrow or monday when I pull my front suspension off and let you know.ericem wrote:Jamal are the ball joints OEM and almost new? New OEM ones are $30 each.
ya something is way wrong w/ my suspension.
i might need some parts from your SS when you come back to MT if so.
i'll let you know when i figure out what the problem is..
Jamal,
I need like like 4 or 5 bolts from the front bumper that hold on the bumper skin. Would you have these?
ok
