Question on '97 Legacy Brighton AT Differential
jricher
Post by jricher »
I have a differential that's noisy, and has excessive side play where it connects to the driver's side axle. I strongly suspect that it's the bearing. Any suggestions?
Specifically, should I replace the differential or replace the bearing? It looks like this may be replaceable without pulling the entire unit. Is this the case, or is pulling the transmission an absolute requirement?
jricher
Bad luck
Post by jricher »
Bearing is pressed on the shaft. Essentially, this is not a FRU...
Any suggestions for locating a replacement unit?
