Wheel STud Keeper
courtjesterclown
Wheel STud Keeper
IM not sure this is in the right section, be here it goes. Last night i was taking off both front calipers to get the rotors turned down and i noticed the driver side had a wheel stud (or lug) that was slightly cross threaded. so i decided to knock it out and go get a new one. So i knocked it out but it was still held in the hub assembly from a keeper ring that mounts on the back of the hub on every other hole with allen headed screws between the studs. I called all the parts places, nobody had any idea what this piece was. Do i really need this piece? Is its only purpose to make sure the lugs dont back all the way out? ANy help is appreciated. thanks.
1994 SS 4EAT Aegean Blue Metallic
