coffee cup problem
subyNW
coffee cup problem
Post by subyNW »
soo i feel really stupid right now but every link on this site that has a coffee cup mod tut. is pretty old and it might be expired or something but i cant find a tut that the link actually works i have been searching forever and i know its right under my nose... please help!!!!
:smt092
thanks
dan
94SS_Canada
Post by 94SS_Canada »
The coffee cup mod is the deletion of the Turbo resonator, The 2nd big black box in your intake, Weld in a pipe with the correct fittings for the vaccum lines and your good to go!
FastRust
RJ93SS
Post by RJ93SS »
it is a reducer that is 6" long, it has 3 nipples for your hose hook ups, measure the id of the hoses that hook up to it and the elbows that go on the ends and make that your od specs for ypur reducer and nipples, everybody's is different but they all work the same.[/img][/quote]
subyNW
Post by subyNW »
ok i get it can i just get a picture haha :P
thanks
dan
RJ93SS
Post by RJ93SS »
i have one in the pic forum, look up 93 ss low km and it will give you a link to the pics
A1Fiddler
Post by A1Fiddler »
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
RJ93SS
Post by RJ93SS »
fids my car use to be as clean as yours, and then idiots started running into it, very nice man, i seen it in the pic gallery too!
RJ93SS
Post by RJ93SS »
that intake doesnt leak?
RJ93SS
Post by RJ93SS »
RJ93SS
Post by RJ93SS »
RJ93SS
Post by RJ93SS »
sorry, i dont know how to post pics so just cut and paste it
fixed pic
RJ93SS
Post by RJ93SS »
thanks josh
A1Fiddler
Post by A1Fiddler »
RJ93SS wrote:that intake doesnt leak?
It's not the best design ever, but I looked and looked and tested it and it seems fine as far as leaks go. I don't think anything's getting in that shouldn't be. BTW, under the electrical tape is JB-Weld.
subyNW
Post by subyNW »
thanks guys hopefully i can start it this weekend =]
New92
Post by New92 »
A1Fiddler:
The red breather next to your airbox, what is it connected to, why did you do it, and how is it working out?
Im assuming it has to do with your canister purge solenoid?
Thanks,
Ben
1992 SS 5MT
She's growing faster in her old age!
A1Fiddler
Post by A1Fiddler »
New92 wrote:A1Fiddler:
Thanks,
Ben
It's connected to the black thing that it's connected to :lol: I did it cause the SOB JB-Weld wouldn't hold my brass fitting on for the tube, and I figured whatever it was, it was going into the air intake before, and only needed filtered air, so I'd be okay making it seperate from the air intake.
It's working out fine, but the first one fell off on the road, which explains all the zip-ties.
G-unit
Post by G-unit »
thats a stock bov with mini filter, what noise it make?
asc_up
Post by asc_up »
It's not a stock BOV. I believe what it's actually called is an auxiliary purge valve and it has something to do with releasing gases from the charcoal canister.
xbn377
Post by xbn377 »
Yeah it purges the gases back into the intake for emissions purposes. Also is part of the purge system to allow the gas tank to breathe so it does not collapse.
Shawn
91 Legacy SS AT
93 Legacy L Wagon
To get your hands on superior lubricant products from AMSOIL utilize the following url:
http://www.amsoil.com/redirect.cgi?zo=1819626&page=store
Well, now it just allows gasoline to evaporate into the engine bay.
Not so sure that's a good idea.
If you don't want to plumb the auxiliary purge system correctly I would just remove that filter and replace it with a cap. Or, better yet, cap off the fitting on the canister and replace that vacuum tee with an inline connector, removing the auxiliary valve from your car entirely.
The primary purge system will still work adequately.
A1Fiddler
Post by A1Fiddler »
I fixed that intake a long time ago guys. I now have everything sealed, installed, and routed nice. I'll try to find a picture.
