Compatible AT for a 93 legacy Turbo wagon
M155L3R
Post by M155L3R »
Sorry if this question is a repeat, I did try to search. But I am having a hard time finding a transmission for my 93 t-wagon. I was wondering what type or range of automatic trans will work in the wagon. I have found some impreza's and legacys here locally all na and under 96. Will any of these work?? Again if this is a repeat sorry.
Greg
04 STI (summer car)
93 Legacy T Wagon (soon to be winter car if i get the transmission fixed)
96 OB (winter car until girlfriend took it over?)
James614
Post by James614 »
The transmissions, both auto and manual, from the turbo Legacys are different (stronger) than any of the n/a cars. I'm not sure about fitment. But even if an n/a trans is a direct drop-in, it's probably not gonna hold up too well unless you have it re-built. And if your gonna do that, you may as well have them re-build your original trans instead of chancing it with a weaker one.
My suggestion, however, is to ditch automatics all together: Touring Wagon 5MT Swap.
Your 93 At has a 3.9 final drive ratio. That's the big thing to keep in mind. All the 91-94 turbo legacy AT's are 3.9 final drive, as well as the 92-94 non-turbo AT's. Some of the mid 90's imprezas may have a 3.9 final drive ratio, but do make sure to check.
