my new set up
my new set up
im a little farther then this now. all thats left to do on the car is wire in the standalone and install the fuel pump.
mods are:
ej22t block
wiseco pistons 8.5 comp
eagle rods
full subaru rebuild kit
20g heads
20g intake manifold, painted the same color as the car
ACT Heavy duty PP with a sprung 6 puck disc
heat rapped exhaust
custom up and down pipe built by my friend, invidia catback
50trim Garrett turbo
custom FMIC built by me
98 LGT fuel rails
565cc Sti injectors
Link Standalone EM
AEM WideBand
Autometer boost guage & oil psi
HKS Bov
Battery located in the trunk
horns behind the grill
Engine bay panted black
custom intake manifold wiring harness
i think thats all, idk
Last edited by 92ss satinsvoice on Wed Oct 15, 2008 5:19 am, edited 1 time in total.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
94 L n/a 5spd, Rip
Maybe the 8.5:1 comp pistons for the 22T heads, and just using different heads. Compression FTW.
What are you going to do for a transmission? I know for a FACT that a 50Trim will blow up a stock trans like it was made of toothpicks.
BAC5.2 wrote:Maybe the 8.5:1 comp pistons for the 22T heads, and just using different heads. Compression FTW.
I did enjoy the 8.5:1 on my 22T longblock and Delta cams. The motor was nice and snappy off-boost, and the torque at 4500 was fun. But alas, a 55cfm increase with 25D heads is hard to pass on.
So a 4.11 final drive?555BCTurbo wrote:I believe he has a stock NA tranny too.
thanks guys for the comments.
for the tranny question, yes im running a stock n/a 5sp. i dont really care right now about blowing up the tranny because there easy to remove/ install and fairly cheap.
i already have an extra thats been rebuilt if this one gos early.
car should be able to drive to a paint shop some time this Sunday.
we got it to run tonight
Andy
94 L n/a 5spd, Rip
94 L n/a 5spd, Rip
