ABS brakes after Turbo Swap
wtdash
Post by wtdash »
My '90 did not have ABS brakes. I'm 99% sure all the Turbos did, which means the Turbo ECU should be looking for them, correct?
I get no codes/no CEL/no BRAKE dash light.
I have no braking issues.
Since I didn't have ABS to start with, does the ECU just ignore it?
Or maybe since I don't have the ABS light, I wouldn't know if there was an issue w/the system?
Just curious.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
n2x4
Post by n2x4 »
ABS is not controlled by the ECU.
The ECU pinout in the library section shows you what goes into the ECU, and gives you a good understanding of what the ECU controls. ABS isn't involved at all, so you're good.
SUBARUEHS Racing
n2x4 is correct, ECU doesn't care about ABS.
