Bad Speedo gear workaround?
chriskatana
Post by chriskatana »
Is there a workaround for the stripped speedo gear in the dif?
Will later model clusters with non cable driven spedo fit?
Culd you use a signal generator to drive that speedo?
I'd really like my speedo odometer to work and I'm sick of looking at the CEL
Thanks,
Chris
1992 Legacy L N/A AWD Wagon.
n2x4
Post by n2x4 »
Why don't you buy a new one?
SUBARUEHS Racing
chriskatana
n2x4 wrote:Why don't you buy a new one?
A new what? speedo gear? The one that goes in the differential?
the one that would require me to drop the tranny and split the case just to replace the gear?
I did read, but not in detail, that the gear can be swapped by puling the passenger axle and removing the bearing. but I'm not 100% confident that it's dooable that way. Plus even if it is, I could ruin my ring and pinion if it's not put back together EXACTLY right.
so, you might understand looking for a workaround on this one...?
Thanks,
Chris
n2x4
Post by n2x4 »
I guess I was confused as to what's broken. If you were to try and use a later electronic speedometer, the speed sensor is still gear driven. If the gear inside the trans is broken, then you're screwed. Not a whole lot of options there.
SUBARUEHS Racing
gijonas
Post by gijonas »
Are you sure the gear is bad?? or is the cable fubar?
chriskatana
I am sure it's the gear.
The simple answer, is no, there's not really an easy way around it.
skid542
Post by skid542 »
GPS unit, mounted on the dash.
Lee
chriskatana
skid542 wrote:GPS unit, mounted on the dash.
Got one. That doesn't fix the check engine light.
gijonas
Post by gijonas »
Electric tape over the light?? Pull the bulb for the light?? Not care??
