Whats the diff between 2.2e and 2.2t pistons/rings
94legacy2.2
Post by 94legacy2.2 »
Just wondering what the actual differance is between the pistons and rings.
I found a set of pistons on Ebay but they say they are for the ej22e motor.
are the pistons the same just higher compression? can I use these and run 15psi with out cracking the ring land or burning a hole in the top of the piston.
Pretty much asking if the 2.2t pistons forged or just normal stuff like the 2.2e stuff
Tyson
im slow---Location:Colorado
Got squirt? http://www.msextra.com/index.php
94legacy2.2
94legacy2.2
I found this on the internet. I didnt know the 2.5 rods were good for anything. Whats the power rating for these rods?
also im just trying to do the fastest rebuild. I need the car running within a couple days.
I might just give the bores a quick hone and slap new rings in it for the time being. Might also install new bearings of course.
All this will happen with a set of dohc heads.
If your starting with a 2.2 turbo closed deck block you need the following to complete a stroker build:
Phase I DOHC Crank
Phase I DOHC Rods
Wiseco Pistons: K602M975 -
Summit Racing
$433.69
http://store.summitracing.com/default.a ... toview=sku
Brand: Wiseco Piston
Product Line: Wiseco Sport Compact Piston and Ring Kits
Bore (in): 3.838
Bore (mm): 97.50
Piston Material: Forged aluminum
Piston Style: Dish
Compression Distance (in): 1.191
Dish Volume (cc): 24.00
Wrist Pin Style: Press fit or floating
Pin Diameter (in): 0.9055
Gapless: No
File Fit: No
Top Ring Thickness: 1.0mm
Top Ring Material: Steel
Top Ring Facing Material: Moly
Second Ring Thickness: 1.2mm
Second Ring Material: Iron
Second Ring Facing Material: Moly
Oil Ring Thickness: 2.8mm
Oil Ring Material: Stainless steel
Oil Ring Tension: Standard
Quantity: Sold as a set of 4.
Pistons and Rings, Forged Aluminum, Dish Top, 97.50mm Bore, Subaru, 2.2L, H4, Set
douglas vincent
Post by douglas vincent »
We have been using the NPR (Nippon Piston Rings) for the NA 2.2 on the 2.2 turbo pistons for some time now with no issues.
94legacy2.2
Mr. Douglas, thanks for the info.
I almost bought OEM rings today for 140.00
So no problems with std bore piston rings?
92ss satinsvoice
Post by 92ss satinsvoice »
doug knows what works when it comes down too it. he's built meny motors and knows the in's and out's better then i know my own hands. just dont try to make turbo power with stock 22e pistons. it will end up with a boom.
Andy
94 L n/a 5spd, Rip
91 ss champagne - Rip
88 Leon GL Hatchback - DD
