outer tie rods
outer tie rods
Post by SILINC3R »
ok so i figured how the everything fits together. found ball joints from Moog and inner tie rods from Moog as well. but cant find a name i can trust for the outer tie rods. should i just buy anyone.
Saskatoon Subaru
Post by Saskatoon Subaru »
Alot of people are gunna tell you to buy OEM for this kinda stuff.
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
SiCkSTi04
Post by SiCkSTi04 »
Moog makes outer tie rods for our cars.
MOOG Part # ES2974 Right Hand - $55 each
MOOG Part # ES2975 Left Hand - $55 each
SUBARU OEM Part # 34140AA030 {Inner Tie Rod End: Left and right} - $32 each
prices / info are from Rockauto.com
What are you calling the inner and outer tie rods?
There's only one tie rod. There's the steering gear box rod.....
Here's pics from the Impreza work.
http://www.main.experiencetherave.com/s ... balljoint/
Post by SILINC3R »
the outer has the little ball joint in it. the inner connects to the part in the boot. what bolt is that at the end, the one that is stripped
Transmission mount bolt.
SLODRIVE
Post by SLODRIVE »
I hate to disagree, but Subies indeed have inner tie rods/ends. They unscrew from the rack behind the dust boot, and thread into the outers. In fact, they're set up like just about every rack & pinion equipped car I've ever worked on.
Here's one for our Leggies on Ebay (posted purely for reference purposes):
ebay link
http://www.slodriveracing.com
-And more!
I stand corrected. I was unaware that those unscrewed from the steering rack. I wonde how difficult they are in coming off. If I new that, I probably wouldn't have wrestled so much with the damn things on the Impreza. I would have just replaced them.
SLODRIVE
Post by SLODRIVE »
They're not awful to get off. I haven't replaced them on a Subaru, but often you can just use a large combination wrench or crescent wrench on the flat spots to unscrew them. Some cars don't have clearance for a wrench, and then you need a special rack & pinion tool, which isn't too expensive if the parts store versions fit. Once you pull the boot back, it'll be pretty clear.
-And more!
n2x4
Post by n2x4 »
I got my tool from Advanced Auto for the inner rod.
SUBARUEHS Racing
