seafoam
joeWM
seafoam
Post by joeWM »
i bought some seafoam and am planning on running it thro. ive looked around and see that the PCV hose is the place to run it thro...haha but which hose is that??
nooby i know.
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
Bdub
Post by Bdub »
The best way to run the seafoam through the pcv is to remove the valve out of the intake mani. and get a vac hose small enough to fit into the pcv valve hole, run it from the can to the hole, and it'll suck it right up.
Be careful not to flood the engine, just do a little at a time.
Also, you'll need to either fiddle with the throttle while you do this, or have someone on the gas pedal, otherwise the car will stall at an idle with it removed.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
n2x4
Post by n2x4 »
While that is the best location, an easier alternative is through the brake booster vac line. It might not balance out evenly, but it works.
SUBARUEHS Racing
joeWM
Post by joeWM »
Bdub wrote:The best way to run the seafoam through the pcv is to remove the valve out of the intake mani. and get a vac hose small enough to fit into the pcv valve hole, run it from the can to the hole, and it'll suck it right up.
awesome thanks
joeWM
Post by joeWM »
i was told this only goes to 1 cylinder tho????? wrong?
skid542
Post by skid542 »
You were told wrong. The PCV valve dumps right into the main airflow of the intake. Seafoam here will go to all cylinders.
And +1 (got it correct this time Nate ;)) to Nate's suggestion to use the brake booster vacuum line. It doesn't distribute quite as well, but after half a can, I'm inclined to think you're getting enough everywhere. That is the location I personally use.
Lee
joeWM
Post by joeWM »
skid542 wrote:You were told wrong. The PCV valve dumps right into the main airflow of the intake. Seafoam here will go to all cylinders.
oh ok, thanks for clearing that up
Post by entirelyturbo »
In terms of central location, the PERFECT place to induct any kind of top engine cleaner is that purge valve vacuum hose right on top of the throttle body... you can see it clearly in that picture. Not only is it centrally located and has the best chance of even distribution to all cylinders, it is small enough that flooding or hydrolocking the engine would be pretty difficult.
However, that engine cleaner might wash the beneficial black goo off the throttle plate. The jury's out on that one.
*Formerly DerFahrer*
Tleg93
Post by Tleg93 »
You may also run it through the gas and oil.
--Scott--
1991 - Rio Red SS
joeWM
Post by joeWM »
Tleg93 wrote:You may also run it through the gas and oil.
i did it today, but it didnt really smoke all that much, so i dont think i put enough in the intake, it took forever for it to suck it all up
James614
Post by James614 »
DerFahrer wrote:However, that engine cleaner might wash the beneficial black goo off the throttle plate. The jury's out on that one.
I want to know how black goo anywhere in the intake tract can be beneficial.
On my old Jetta I cleaned a ton of block goo off the mechanic MAF plate and the throttle blades and that thing went from a snail to a snail with better throttle response.
Buffman
Post by Buffman »
in the gas it's a horrible cleaner. Seafoam is best used as a top end cleaner through sucking it in while running..
1992 Legacy LS Special Wagon..
Everyone says to use a hose and put it in the can but I did that and even with a lot of throttle it still killed the engine pretty much instantly.
I just got a hose with a small funnel in the end of it and poured it in a little bit at a time while holding the throttle open probably 3-4K rpm and then when I had about half can in there I let go of the throttle and let it suck up enough to kill the motor and let it sit for 15 mins. Then started it up and took it for a spirited drive to burn it all off. I never noticed any difference on that car but I never had any problems with the motor to begin with.
The other legacy I did it on had really bad lifter noise afterwards. But after a day or two the noise went away. I was pretty freaked out during that time though. Thought I had fucked up the motor.
James614 wrote:I want to know how black goo anywhere in the intake tract can be beneficial.
From what I understand, the black goo that surrounds the throttle plate helps seal it closed, thus allowing more accurate air metering through the IAC valve and giving a more stable idle.
James614
Post by James614 »
The airflow restriction (especially under light throttle) doesn't cancel out that benefit?
I've never heard of a car where the throttle blade(s) worked in any better condition than squeaky clean. But then again, not too many people clean the rest of the intake and leave the TB dirty for comparison, so I dunno... Sounds plausible.
The TB's with the needle valve adjustment.....if you remove the black sealant, you'll cause yourself issues especailly if you don't know about the sealant. You'll have a high idle and can't figure out why. Been there, done that, cussed a lot.
http://www.main.experiencetherave.com/subaru/images/TB/
James614
Post by James614 »
So, is that goo pre-applied or build-up? Looks pre-applied, but the context I've heard it used in implies a build-up? (otherwise I'd think you guys would refer to it as actual sealant)
It's pre-applied from the factory.
