individual throttle bodies
i know they make these for hondas and acuras but what about our cars. since i have decided to stick with N/A on my car these would help out if they made them which im sure they dont but if they do i would for sure get them and show them to everyone
if you were able to find them, most likely they would charge $1200-1500+ for a kit. If you can tig and you can get either a kit for another 4 cylinder or take a v6 or v8 setup because the throttle linkage is shared between the banks of cylinders. Its expensive either way, and unless you have the cash and want something unique its not worth the 15-20hp.
well i think it would be cool and i knew they would be expensive, but i would want to buy one already fabed up
Like I said in the other ITB post WRX TGV's can be modded & turned into ITB's with injector bosses CHEAPLY.
The TGV's bolt right onto Phase II SOHC MAP Subaru motors, MAP sensor can be fed through a barb fitting behind the throttle plate, TPS mount will have to be fabbed.
An adapter plate could probably be made to get TGVs to bot onto a PI motor OR the lower flanges can be cut off & ones with the proper flange pattern can be welded on but the MAF is gonna spoil the open velocity stack fun that the MAP cars can potentially have...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
96 Impreza OBS
99 Impreza OBS-T
I saw a picture of a guy that did this, but he used the individual velocity stacks that were produced for the K16? motor that was in the old datsun 510's he just made a cool adapter plate that went between the head and veloc stacks
-93 2.2T (RIP), 93 N/A best car on earth.
-00 legGT, 18" PIAA sport mesh wheels, front/rear Rallitek sways, lowered whitelines, coming soon: 2.5L sti internals, 20g heads P&P, twin charged. motor is almost ready to go in.
Andrew
Andrew
dont have any pics of the datsun subaru set up. but i did find this. the same principles apply just dont put boost to the individual plenums
www.youtube.com/watch?v=ta6iJiKbfHg
http://www.tristatetuners.com/forum/sho ... hp?t=23730
http://forums.nasioc.com/forums/showthr ... ?t=1175829
Andrew
Andrew
is that what Frankenstien looks like. so you need a turbo to use it. cause i thought of getting this since i wasnt going to a turbo for help
oh yea and thanks for the pics and vids. kind of makes some sense now
so how much you think it would cost to do this, like seriously.
well they way their CAD drawings were laid out. looked like they made all that stuff, But something is telling me that they stoled some of the design. To do something like what they had probably looking at 5k 'ish. With a little ingenuity and patience i bet you could fab something 500 bucks er so.
Andrew
Andrew
thats right, it was starting to bug me, that i couldnt remember555BCTurbo wrote:thehookeup wrote:I saw a picture of a guy that did this, but he used the individual velocity stacks that were produced for the K16? motor that was in the old datsun 510's
L16
Andrew
Andrew
I've seen a set of these for the past few years at Cobb. They've never used them. Maybe I should ask if they want to sell them...
Legacy Central
and you are my heroDLC wrote:I've seen a set of these for the past few years at Cobb. They've never used them. Maybe I should ask if they want to sell them...
