Soldering Help
Soldering Help
I've got the wiring harness prepped for the Link and plan to solder the wires from the stock Link harness to an adaptor board. I can solder, but I wouldn't say I'm an expert. So I'm looking for suggestions on soldering the wires to the board. The holes in the board are a decent amount larger than the wire.
Any help/suggestions are welcomed.
That's a good idea.
Thanks!
Thanks!
Another suggestion is to get a nice soldering iron with a small tip. They make irons specifically for boards and they will make a big difference in your enjoyment of soldering such small items.
I'd also suggest getting a roll of really thing soldering wire. Again, they make wire specifically for small board work and this will drastically help you keep the solder where you want it and keep it out of places you don't.
Otherwise, take your time and be patient .
Lee
Thanks.
I did buy some thin solder, and will look into a small tip soldering iron.
Just a thought, and it may be good or bad so chime in people, but can you fold the wire over once, or maybe twice before trying to solder it? You can take up a lot of slack that way. I've done that with butt-splice connectors and have never had trouble, even when yanking on them after crimping. Granted, soldering is different, but if you are looking to reduce the gap...
Since you have a large hole, make sure you don't end up with a 'cold joint' as you're filling it in with solder. For closing the gap, not much you can really do besides whats been suggested -- double/triple the wire thickness or put extra solder in the hole.
A decent guide to getting started: http://www.aaroncake.net/electronics/solder.htm
'11 WRX Limited
'94 TW | R.I.P.
Good suggestion Dan. That is a possibility.
I'll have to check out that site when I get home.....work blocked it....
Worked on this today. Everything went pretty well.
Good deal, in followup advise I would say when working with PCB connections:
1) tin the wire first, always
2) use an appropriate low-watt setting and tip size, you don't want to "cook" traces off the board
3) put solder in the hole first, then heat the tinned wire up, then get the hole just fluid and push the wire in, the solder from both should fuse at that point
4) don't jiggle the wire until it is certain that the joint is cool
Sounds like you had no trouble though.
1991 SS build thread: http://bbs.legacycentral.org/viewtopic.php?t=40430
Thanks for the follow up. I'm sure my soldering was sloppy compared to someone that knows what they were doing, but everything seems alright. I checked out all the wiring yesterday.
I've updated my thread with the progress & pics.
http://bbs.legacycentral.org/viewtopic. ... 931#286931
thanks
thanks
I actually work at radioshack and my friend just started there and worked at a car audio shop and suggested using silver bearing solder, because it is very easy to use. He used that when he did remote start and security installs. I took his advice and i really like the silver bearing solder it flows really easy and has made soldering wires a whole lot easier. Hope this helps out!
Shawn
91 Legacy SS AT
93 Legacy L Wagon
To get your hands on superior lubricant products from AMSOIL utilize the following url:
http://www.amsoil.com/redirect.cgi?zo=1819626&page=store
91 Legacy SS AT
93 Legacy L Wagon
tturnpaw - I hope you're kidding. You should only apply just enough solder to the tip to allow it to conduct heat to the wires/components/traces you're soldering. The joint is made with fresh flux-core solder applied to the heated components. You should use an iron big enough to quickly get the components to temperature without heating everything else up, but use as little heat as possible. The glue holding printed circuit board traces to the board often melts at a lower temperature than solder.
roundeye - He's not talking about silver solder. Silver bearing solder is just regular soft solder that has silver in the alloy. In particular, Radio Shack's silver bearing solder is nearly eutectic tin/lead except that it's 2% silver.
Good old lead. I grabbed a big roll way back when they were disposing of the stuff to move to the lead-free garbage. "I don't always solder, but when I do, I prefer lead."
