Custom downpipe
subytech
Custom downpipe
Post by subytech »
Just a little project I've been working on. I know the welds aren't pritty and the flow patterns may not be optimal for all the engineers out there and i dont care i had fun making the jig and the DP and the car pulls hard now with my new injen SS exhaust, its a de-catted stock dp and some pipe from the stock header off my old ZX-6R!
92 Legacy Turbo, 5sp MT, Early Large CC 20G heads, Ported custom clocked td04, Cobb catted DP, Injen SS 3" exhaust, Turbosmart MBC @ 10psi, Apexi 20g intake, custom FMIC, Fidanza 11lb flywheel, stock 05 WRX clutch
SLODRIVE
Post by SLODRIVE »
I like it. Nice work!
http://www.slodriveracing.com
-And more!
Looks good!
Nice DIY action from used parts.
BXSS
Post by BXSS »
Cool
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
gijonas
Post by gijonas »
Sweet project,any boost creep?
subytech
Post by subytech »
gijonas wrote:Sweet project,any boost creep?
Yea, less than before but i'm not sure if its from the new DP or the fact that I put a different intake manifold on (from another ss). I added two vacuum ports on the manifold, one for my MBC and one for my boost gauge. So now the MBC gets it's signal from the manifold instead of the compressor outlet. I also have a FMIC and before the new manifold, with the stock DP I would creep almost 4 psi in a 4th or 5th gear roll on in the free way, now i'm down to about 1-2psi.
BXSS
Post by BXSS »
Ever thought about an atmo dump for the actuator tube?
Alot of 4g63 guys do this...
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
asc_up
Post by asc_up »
I was thinking about doing that! I be the flange in between the WG and downpipe would have to fit snuggly, otherwise you'd probably get a ton of exhaust noise out the dump tube.
subytech
Post by subytech »
I had a friend that welded a dump pipe onto the stock dp on his STi, sounded funny to me, and i think this looks cooler to lol.
logan9691
Post by logan9691 »
just remember...mine pulls harder :D
VF43 custom FMIC APEXI intake Invidia 3" TBE JDM Ver. 4 RA STi trans (4.44) SPT short shifter rear LSD WRX rear axels coilover suspension JDM 4-pot front brakes drilled slotted rottors Greddy EBC tuned 20G ECU sti 550cc injectors Jecs MAF walbro 255
