Like it says, a v2 slant-mount TMIC I need to get rid of. Not currently in my wagon but I included a pic for reference. I also have a matching scoop with shroud that I can include as well. I would like to get $200 for the lot, or whatever anyone is willing to give me for it.
Matt Monson wrote:Can you post a picture of the backside since that's clearly not a factory inlet?
That looks exactly like mine does, inlet included. Mine has a "motorsports use only" sticker on it. I figure it's either a really early STI, or possibly a "catalog" item. I can PM you pics Matt, if your doing research.
Sorry for the O.T.,........... bump! It's a much better flowing inlet than a standard "black slanty".
That's right PhyrraM, it's off a version 2 JDM STI that actually came out of a '96 donor car.
Matt, I can also send you pics if you are interested.
Cool,
Thanks for the pictures. That's a factory aluminum inlet pipe with some sort of aftermarket silicon elbow replacing the plastic elbow. Let me know if you decide to move on that price. That's more than I am willing to pay, especially since all I actually need is the pipe.
2000 2.5RS daily driver.
1999 2.5RS w/ 50+ extra whp
Suby Hai!
My '95 STi Ra swap had this EXACT same Silver TMIC/elbow/connector.
I think this is a stock STi set-up as three of us have/had the same TMIC/elbow/silicone connector (PharraM's, this one, & mine).
The cast elbow is actually very nicely machined internally from the factory (has a taper to match smallish inlet to the larger diameter elbow body).
BXSS wrote:My '95 STi Ra swap had this EXACT same Silver TMIC/elbow/connector.
I sold mine on Rs25 - ? posting up there.
You are right BXSS this is the stock intercooler off a '96 V2 STI. I hadn't thought of listing it on Rs25 - I will have to check that out.
Kramer
'90 Leg LS wagon ver. 2 STI swapped
'08 Honda Ruckus modded
