throttle body?
throttle body?
Does anyone know how difficult it is to flip the throttle body on the ss, i am trying to fit a wrx top mount . i was also looking at the wrx bypass valve and the recirculat looks like it could be fliped over with a little help from the rotary tool , i am going to see if that works for clearing the throttle cables before i flip the throttle body unless anyone objects.
92 ss 5MT..TD04, 02' Wrx TMIC, XS power Atmos. BOV and Gripforce stage 2 w/ WRX OEM Flywheel, Equal length headder and catless uppipe. Open DP and soon tobe CBE, WRX struts and springs, MBC
ya, i bought an 04 TMIC and read later on here that you have to hammer in the firewall, as well as a few other things in order to get it to fit. if i were you id get an 06/07, or i even heard the forester xt ones work pretty well too or some of the saab ICs too
The early TMIC can be fit without hammering the firewall... my solution was to turn back the throttle body. The engine shown below is a JDM EJ20G but the relative position of the manifold/TB is the same as the stock EJ22T. I turned the TB back on a lathe, but you could probably get it done with a dremel and a flie. It cuts behind the spring pin mount area, right up the air bleed screw. You can see the clearance at the firewall in the second pic. (don’t mind the messy plumbing, it was a temporary install) Also note the relocated BOV for clearance with the IAC and throttle linkage.
![Image](http://img.photobucket.com/albums/v204/All_talk/Subaru/P7190678.jpg)
![Image](http://img.photobucket.com/albums/v204/All_talk/Subaru/PB050095.jpg)
Gary
Gary
Thanks for all the info,i think i have read through the entire intercooling section of the forum, but my main issue is with the oem wrx bov clearing the throttle linkage , do you think that flipping the resirc on the bov itself would give clearance or no. I do have a 04 TMIC i know it is not the best for this application but it was a gift from a friend and it is just to hold me over until i get my FMIC all sorted out,
Thanks y'all,
-Nick-
Thanks y'all,
-Nick-
