Pretty Simple Question, I think
destrovel
Post by destrovel »
I have a 91' Legacy AWD, no turbo.
completely stock, as far as I can tell, and i was wondering what I could do to the stock exhaust system to perhaps get a bit more sound out of it, without going all honda-sounding. is there a silencer in the stock system? if so, is it easy to take out? just little things like that
GodSquadMandrake
Post by GodSquadMandrake »
You could get a cat-back but that means money.
Are you asking if you can do something for free?
You can de-snorkel your intake + K&N filter and make it louder.
-Doug Wilson
An axle back exhaust, or just swapping the muffler will give you better sound.
If all you want is a little more sound for free, punch a hole in the muffler. Or remove the muffler gasket and replace it with two thin washers. :)
gijonas
Post by gijonas »
Tailpipe turbo simulator?
93Leg-c
Post by 93Leg-c »
vrg3 wrote:If all you want is a little more sound for free, punch a hole in the muffler. :)
My laugh for the day! :-D
'94 TW
Skruyd
Post by Skruyd »
Cut off muffler. Get a clamp and pipe , I think it was 2", from your local Auto parts place and install.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
destrovel
Post by destrovel »
haha thanks all. sorry for the dbl-thread, thought this one didnt go through
91' Legacy, Manumatic, Turbo-less (will get fix'd)
destrovel
Post by destrovel »
is there a silencer on stock exhausts? that would help if i took it out. id check if the car was at this house.
SubiePrice88
Post by SubiePrice88 »
thats what I said in the other thread of the same topic.
If you have 5 minutes and a saws all (even a hacksaw) just cut the muffler off. its Free!
-Jordan
"Nothing Stings Like a Subee"
1993 Legacy Wagon, 5MT, 220k!
destrovel
Post by destrovel »
haha okay, will do.
destrovel
Post by destrovel »
while im at it, does anybody know what it would cost me to switch out the tranny to a manual? i cant stand automatics, and would like to get a change. for me paying a mechanic to do it, that is.
SubiePrice88
do a search for it. Its been done before.
oh and Welcome! this place has tons of info!
Goodluck :)
-Jordan
SubiePrice88
infact its a sticky under Drivetrain
-Jordan
A1Fiddler
Post by A1Fiddler »
You can gut your mid-pipe.
'92 Legacy Sport Sedan - EJ22T, 4EAT, AWD - Snorkle Delete, Custom Grounding, 3" Catless TBE.
Mattheww044
Post by Mattheww044 »
there should be a resonator you can get taken out and a pipe welded in there, KNN, and just like an sti muffler or something of the sort would sound GREAT!
fishbone79
Post by fishbone79 »
I ran strait pipe from the cat back fro a while. It sounded badass, but it was LOUD (set off car alarms, Harley Davidson loud). I had to put a muffler on when I moved - it was too loud for suburban NJ. It does have good tone and backpressure with a high flow muffler though, I think the stainless magnaflow meant for a mustang fit in there perfectly, but I stepped up to 2.5" from the axle back.
destrovel
Post by destrovel »
Thank you guys alot! For now, i think i may just cut it off, and keep the cut off bit for when the cops get ancy in mid august (western SD, Sturgis Bike Rally always heats things up :P) question though, where should i cut it off? back by the converter? up by the tip?
asc_up
Post by asc_up »
In all seriousness, you should do what Vikash suggested and remove the gasket in between the axle-back and mid-pipe and put two washers in its place. That'll help to un-muffle everything, but it won't be RIDICULOUSLY loud.
SLODRIVE
Post by SLODRIVE »
asc_up wrote:In all seriousness, you should do what Vikash suggested and remove the gasket in between the axle-back and mid-pipe and put two washers in its place. That'll help to un-muffle everything, but it won't be RIDICULOUSLY loud.
+1. It's free and completely reversible, plus some people have been known to "tune" their exhaust sound by adding/removing washers. It's kinda redneck, but who cares? Just don't tell your buddies, lol.
http://www.slodriveracing.com
-And more!
destrovel
Post by destrovel »
ah okay, that sounds good too. I have a few ideas as well. will try and keep yall posted. also, did alot of 91 legacies have manumatics? iv never even seen one before..
destrovel
Post by destrovel »
hmmm i have some really nice aluminum tubing i got from dissasembling some hospital equipment, could make a nice tip. and i have some straight pipe(s) i got when i took the stock exhaust off my truck. easy as pie...right? haha guess we will see. ill have the car here by the weekend hopefully, had to file for an abandonment title because the previous owner had a joint signed title between him and his (ex-) girlfriend :P
legacy92ej22t
Post by legacy92ej22t »
My LOB blew the flange for the spring bolts clean off, the donut gasket is gone so I pretty much have a straight pipe system at the cat. It is sooooooooo frickin' loud that it hurts my ears. The after fires sound dope as shit though, almost like an anti-lag system. hahaha
I need to get it fixed... Anyone have a OEM LGT cat back they want to part with cheap?
-Matt
'96 Outback 5mt.
'07 Legacy 2.5i SE
[quote="Redlined"]
destrovel
Post by destrovel »
legacy92ej22t wrote:My LOB blew the flange for the spring bolts clean off, the donut gasket is gone so I pretty much have a straight pipe system at the cat. It is sooooooooo frickin' loud that it hurts my ears. The after fires sound dope as shit though, almost like an anti-lag system. hahaha
sorry mate, id like to keep mine for now... and id like to be able to go to deadwood and set off car alarms, so straight pipes with a aluminum 3" tip sounds like it will be loud enough... and becuase of sturgis bike rally, cops cant really complain about the noise that it will make when the bikes are just as loud.
